Homework Help: A rod kept inside a cart
  1. Mar 12, 2016 #1
    Titan97
    A rod of mass m is attached on the ceiling inside a cart of mass 6m kept at rest. Length of rod is L. Find the velocity of rod with respect to cart when the rod becomes vertical after releasing it. The rod is free to rotate about its point of suspension.
    2. Relevant equations
    Conservation of energy and momentum
    3. The attempt at a solution
    With respect to earth, let velocity of center of mass of rod be ##v_1## and velocity of cart be ##v_2##.
    Using COE,
    $$mg\frac{l}{2}=\frac{1}{2}mv_1^2+\frac{1}{2}(6m)v_2^2$$
    Since centre of mass remains at rest, ##mv_1=6mv_2##
    $$V_1=\sqrt{\frac{7}{6}gl}$$
    So ##v_{\text{rel}}=\frac{v}{6}+v##
    But I am not getting the correct answer.
  3. Mar 12, 2016 #2
    TSny
    2017 Award
    Is one end of the rod attached to the ceiling of the cart so that the rod is free to rotate about this end?
    Did you account for all of the KE of the rod?
    Also, the problem statement doesn't specify which point of the rod is used when finding the "velocity of rod with respect to cart".
  4. Mar 12, 2016 #3
    Titan97
    @TSny question edited. They have used concept of reduced mass to solve it. But wrong in my method?
  5. Mar 12, 2016 #4
    TSny
    2017 Award
    You have left out some of the KE of the rod.
  6. Mar 12, 2016 #5
    Titan97
    Oh. Is it the rotational kinetic energy?
  7. Mar 12, 2016 #6
    TSny
    2017 Award
    Yes.
  8. May 8, 2016 #7
    Hello , I get ##\frac{\sqrt{21gl}}{5}## as the answer .Is this what I should be getting ?
  9. May 8, 2016 #8
    TSny
    2017 Award
    Yes, I believe that is the correct speed of the center of the rod relative to the cart when the rod is vertical.
  10. May 8, 2016 #9
    Thanks
Have something to add?
Draft saved Draft deleted
