A Rolling Disk
  • Thread starter kenricktan
A solid, Uniform disk of radius 5.00 cm and mass 1.50 kg is rolling without slipping a long a horizontal surface. The disk makes 2.00 revolution per second
a. Find the total kinetic energy (translational + rotational) of the disk
b. Find the minimum height h of the step (placed in front of the rolling disk) that will prevent the disk from rolling past it. (Hint: assume that the hight h is adjusted so that the disk rolls just up to the top of the step and stops. Conserve Energy)
W= 2.00 Revolution x 2pi radian
V = wr
I = (1/2)mr^2
KE_rot = (1/2)Iw^2
KE = (1/2)mv^2
a. I assumed that K_total = KE_rot + KE
K_total = 4.46 x 10^-3 Joules
b. I have no Idea how to solve this....help?
Answers and Replies
The height must be such that energy will be conserved between the initial translational and rotational velocity and the final trans/rot velocity. Ktotal(0) + U(0) = Ktotal(1) + U(1)
I'd begin by drawing a picture. What does the final total Kinetic energy have to be?
I tried using 1/2 m Vo^2 + mgh(o) = 1/2 m V1^2 + mgh(1)
and since it says that assuming that it "stops" at the top of the step so I set V1 = 0
and also h(o) = 0
cancels all of the m
so I get h1 = Vo^2 / 2g
Is that right?
OK let's stop right here for a sec. 1/2 * Vo^2 is the translational kinetic energy, but you also need to include the rotational kinetic energy because the object is rotating as well as moving forward.
Related Threads on A Rolling Disk
  • Last Post
  • Last Post
16K
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
