Calculating Tension in a Moving Rope: A Differential Equation Approach
  • Thread starter sapsapz
  • Tags
    Mass Rope
In summary: L = pT-(T+dT)=p*dL*r*w^2-dT=p*dL*r*w^2and then somehow replacing dL with dr to get T as a function of r?dm/dL = pT-(T+dT)=p*dL*r*w^2-dT=p*dL*r*w^2The tension in the rope is a function of distance from the attached end.
sapsapz
Given a rope with a constant length L, and a mass M.
The rope is connected in one side, and moving with angular velocity on a frictionless surface.
What is the tension along the rope?
Hint:
Look at a small mass element of the rope and consider the forces acting on it, and therefore arrive at a differential equation.
Im a bit new to this way of looking at problems by looking at them in very small parts, but it does look beautiful, so any help with getting me acquainted with it will be much appreciated! I do have the math needed, but not the intuition of how to break a problem to its infi parts.
So, since an angular velocity is mentioned, I obviously thought about a circular movement. The rope is moving along the circumference of a circle. Which means a force F must be applied to its connected end, and the force pointing to the center of the circle.
On the other hand, when I look at a very small element of rope, its a particle moving in circular motion. But what are the forces acting on it? F would act only at the connected end, wouldn't it? So the force acting on the particle is T1 towards one side tangential to the circle, and T2 towards the other tangential side? How does that explain it's circular motion? (he must have some force towards the center, not on the tangential axis)
What force causes the circular motion when looking at a very small mass particle?
Any help would be much appreciated!
Welcome to PF;
You have done free-body diagrams before?
Model the rope as lots of little masses separated by massless ideal ropes just like in those diagrams only where you had only two or three masses, here you have lots of them.
The force F is only applied to the mass nearest the center - yes.
But that first mass has a tension force the other way.
Hi!
Thanks for the response!
I did do free body diagrams before, but those were very simple. I never did one where you need to consider infinitely many small elements. My my issue is with the specifics of breaking this problem to the little masses you mentioned. I know its the way to go, I just don't know how to do it.
I added a picture from which I don't know how to continue.
The statement of the problem is unclear to me. What does it mean "is connected in one side"? Does it form a circle? If so, there's no dT. The tension will be constant. Instead, consider dθ and dm. You have a mass dm = ρrdθ, two instances of T in almost opposite directions (difference being dθ), and a resultant centripetal force.
Hi! Thanks so much!
Would you mind explaining a bit more about the equation you wrote, dm = ρrdθ?
How did you arrive at it? What does p,r represent?
sapsapz said:
Hi! Thanks so much!
Sorry, I hoped the choice of letters was sufficiently standard as to be self-explanatory.
ρ is the density (mass per unit length) of the rope.
In polar co-ordinates centred on the centre of the circle, (r, θ) is the location of an element of the rope subtending dθ at the origin. Its length is therefore rdθ and its mass, dm, is ρrdθ.
The centripetal force will bisect dθ, and will be provided by the radial component of the tension (each side of the element).
Can you obtain an F=ma equation from that?
Thank you! So, if I have dm = ρrdθ I have F=ρ*dθ* r^2 * w^2, right? And there are 2 tensions causing the force F, which is T*d0/2 (I added a picture of finding F, do you mind telling me if I am on the right track?).
So 2*ρ*r^2*w^2=T?
Where is the expected differential equation?...
And also, theoretically speaking, how do we know that the tension is constant in the rope?
Is it possible that the question is referring to this scenario (in the added picture),
and therefore:
dm/dL = p
T-(T+dT)=p*dL*r*w^2
-dT=p*dL*r*w^2
Yes, I think that may be the intent. OTOH, it means the tension is not constant but is a function of distance from the attached end. "What is the tension along the rope?" makes it sound as though it is one value.
dm/dL = p
T-(T+dT)=p*dL*r*w^2
-dT=p*dL*r*w^2
Yes - except that I would have written dr everywhere you've written dL. L is the total length. Whether it's + or - depends which end you're measuring from. I would measure from the fixed end, so tension should increase with distance.
Edit: Uh, sorry. Misread the response :D
sapsapz said:
Thanks! And how can I replace dL with dr? I can't find the right connection between them, although it seems it should be really simple
As I said, I would not have written dL in the first place. If r is the distance of an element from the fixed end, the length of the element is dr, so it's dm = p dr.
Thank you! So, is this correct?
dm = p*dr
T-(T+dT)=dm * r * w^2
T-(T+dT)=p*dr* r * w^2
dT/dr=-p*r*w^2
T=-0.5r^2 * p * w^2 + C
Is this correct? And... how do I determine C?
Looks good. To determine C you need a boundary condition. Is there some value of r where you know what the tension must be?
Nope, there is no such boundary condition. However, perhaps I can know something about the tension in the farthest point of the rope? The length is L, so I can write an f=mLw^2 equation there, if only I knew what m to apply. Its not the entire mass of the rope, right?
What forces act to the small piece of rope at the farthest point of the rope? Is it something pulling it outward?
ehild
I think that on the outer point there is only T, the max T, inward. Causing the circular motion.
At the end of the rope, only the inward tension acts on a small piece of the rope. So dmRω2=T(R). dm can be arbitrary small. What about T(R)?
ehild
Well, according to the obtained equation, T(L)=-0.5L^2 * p * w^2 + C.
And as you say, considering the forces, -dmLw^2=T(L). And p is M/L, and dm=p*dL
So:
dmLw^2 = 0.5L^2 * p * w^2 + C
dmLw^2 = 0.5L * M * w^2 + C
C=dmLw^2-0.5L * M * w^2
C=Lw^2(dm-0.5M)=-0.5MLw^2
So:
Dropped a minus sign.
I did that intentionally, since both Ts should be in the same direction. Is that wrong?
dm is as small as you like. And T is proportional to dm. At the end of the rope there is only one molecule... Its mass is practically zero compared to the mass of the rope. How big force is needed to keep it circular motion?
ehild
Practically zero I suppose. But what's wrong with my equations?
C shouldn't be zero according to that.
I tried to guide you that the tension is zero at the end of the rope. lim(r->L) T(r)=0.
You got correctly in post #12 that
T=-0.5r^2 * p * w^2 + C.
The tension decreases outward.
Now you changed the minus to plus. Why?
If r=L, T=0. What is C then? ehild
1. How do you calculate tension in a moving rope using differential equations?
The tension in a moving rope can be calculated using the differential equation of motion, which takes into account the mass, velocity, and acceleration of the rope at any given point. This equation can then be solved for the tension at a specific point on the rope.
2. What is the significance of using a differential equation approach for calculating tension?
A differential equation approach allows for a more accurate and dynamic calculation of tension in a moving rope, as it takes into account the changing variables of mass, velocity, and acceleration. This is particularly useful for situations where the rope is experiencing varying forces, such as in a pulley system or when being pulled by a moving object.
3. Can you provide an example of calculating tension using a differential equation approach?
For example, if a rope with a mass of 2kg is being pulled by a force of 5N at an acceleration of 2m/s^2, the tension at a point on the rope can be calculated by solving the differential equation T - 2kg(2m/s^2) = 5N, where T is the tension in the rope. This would result in a tension of 9N at that point.
4. Are there any limitations to using a differential equation approach for calculating tension?
One limitation is that the differential equation approach assumes that the rope is a continuous and uniform object, which may not always be the case in real-world scenarios. Additionally, it may not take into account other factors such as friction or elasticity of the rope.
5. How can the results of the differential equation calculation be applied in practical situations?
The calculated tension values can be used to determine the strength and stability of a rope in different scenarios, such as in engineering and construction projects. It can also be used to ensure safety and prevent the rope from breaking under excessive tension. Additionally, the results can be used to optimize the design and usage of pulley systems and other rope-based mechanisms.
9K
