A Short-Circuit Question
  1. Nov 1, 2014 #1
    A single uniform underground cable linking A to B, 50 km long, has a fault in it at distance d km
    from end A. This is caused by a break in the insulation at X so that there is a flow of current
    through a fixed resistance R into the ground. The ground can be taken to be a very low resistance
    conductor. Potential differences are all measured with respect to the ground, which is taken to be
    at 0 V
    In order to locate the fault, the following procedure is used. A potential difference of 200 V is
    applied to end A of the cable. End B is insulated from the ground, and it is measured to be at a
    potential of 40 V.
    a) What is the potential at X? Explain your reasoning.
    The potential applied to end A is now removed and A is insulated from the ground
    instead. The potential at end B is raised to 300 V, at which point the potential at A is
    measured to be 40 V.
    b) What is the potential at X now?
    c)Having measured 40 V at end B initially, why is it that 40 V has also been required at end A for the second measurement?
    d) The potential gradient from A to X is equal to the potential gradient from B to X. Explain why this is true
    2. Relevant equations
    Ohm's Law
    3. The attempt at a solution
    The answers are:
    a) 40V
    b) 40V
    c) So that X is at the same potential and then the same current flows into the ground through R
    d) Because the same currents flowed along AX and BX
    What I don't understand is the physics behind it. Why is there no current from X to B in question a? Why must there be the same current when applying 200V at A and when applying 300V at B?
    If you want a diagram it is question 12 of this doc: http://www.physics.ox.ac.uk/olympiad/Downloads/PastPapers/BPhO_AS_2007_QP.pdf
  3. Nov 1, 2014 #2
    Staff: Mentor
    Welcome to the PF.
    There are a couple key concepts here. First, when you insulate B from ground and apply the voltage at A with respect to ground, current flows to the fault and into the ground. No current flows from X to B, because there is no load at B for the current to go through. The voltage at B is the same as it is at X in this situation, since no current flows from X to B (hence, no V=IR drop).
    When you insulate A and drive a voltage into B with respect to ground, you get the same situation -- makes sense?
    The second key concept is that they are setting the A and B voltages in this test to give the same voltage drop across the resistive fault at X. What does that mean about the 2 test currents that are involved? And then what does that imply about the "voltage gradients" in V/km? Why?
  4. Nov 1, 2014 #3
    Does 'insulate' mean that no current can passed through this point; i.e. the wire is disconnected? Then I completely understand that.
    The second part might just be a wording of the question that caught me. When they say they apply a potential difference at B, do they mean they gradually increase it until they get 40V at A; because I thought they question meant they applied an arbitrary voltage (200V then 300V) and still got the same potential at both ends.
  5. Nov 1, 2014 #4
    Staff: Mentor
    They must monitor Va while increasing Vb. That's how they got the Vx=40V for both test cases. Glad it makes more sense to you now. What do you get for d now?
  6. Nov 1, 2014 #5
    I get 160/d = 260/(50 - d), which gives me 19km.
  7. Nov 1, 2014 #6
    Staff: Mentor
    And I get (160V/260V)*50km = 19.23km. Good job! :-)
Have something to add?
Draft saved Draft deleted
