A shorter proof to 0.999 = 1
  • Thread starter waterchan
  • #101
352
rachmaninoff::
Hey thanks for pointing out my error, ill use [itex]\overline{x}[/itex] Instead of [itex]x infty[/itex] from now on ;) Atleast you understand my point and I wasnt called a wacko :lol:
nice proof bao_ho, btw.
  • #102
Zurtex
1,120
eNathan said:
rachmaninoff::
Yeah, kind of my point, with all the infinities floating round I still can't really make sense what you are saying.
  • #103
EnumaElish
2,304
124
bao_ho said:
1 / 9 = 0.1111recuring
0.9999recuring / 9 = 0.1111recuring
then 1 = 0.9999recuring
Your 1st step assumes your conclusion, when you replace 1 with "0.9999recuring".
eNathan said:
Sorry I forgot the latex code for <> or !=, what is it again :rolleyes:
\ne
  • #104
Zurtex
1,120
It's not a rigorous proof on many levels but it doesn't do that. It is showing that you get the same answer when you divide both of them by 9, hence they must be the same number.
  • #105
EnumaElish
2,304
124
Okay, I got you.
  • #106
376
It is wrong to say that 1 / 3 = 0.3...
Despite math ascertion to the otherwise it should be:
1 / 3 = 0.3... r 0.0...1
You try doing it on paper and see if you don't have to keep carrying the one.
  • #107
arildno
Dearly Missed
9,970
134
Complete nonsense. Learn some maths before posting.
  • #108
JasonRox
I concur with arildno.
When is the Pi=3 thread going to come back up?
  • #109
HallsofIvy
41,833
963
The greatest number of all real numbers. Obviously, you won't be able to find what number actually infinity is.
@eNathan:
How come 1 - 0.99... = a row of 0s? Where is the little number 1.
I agree 0.99... = 1, but your proof does not make much sense to me.
Viet Dao,
If there WERE a "greatest number of all real numbers" many important theorems in mathmatics would be untrue. Perhaps the most important of them would be the "Archimedean Property of Positive Integers": If x is any real number, there exist a positive integer, n, with n> x".
Fortunately for us all, there is NO "greatest of all real numbers" and "infinity", however you define it, is NOT a real number.
  • #110
Integral
Staff Emeritus
56
Fortunatly we do not have to do it on paper.
Now, I have to point out that your notation is faulty or at least it does not work the way you want it to. You seem to want to claim that .00...1 where the ellipsis represents a infinite number of zeors has meaning. In a well formed decimal number every digit must have a place value, as soon as you place the 1 you have terminated the string of zeros, thus the difference really represented is 1-.999...9 a finite length string of 9s. Of course this difference is greater then 0. Since .999... represents an endless string of 9's you can never reach the end so the 1 never appears.
Contrary to your apparent claim, infinity is NOT just a large real number.
  • #111
376
Hi Integral
The only reason we are disallowed from using 0.0...1 notation - even though it is easy to work out what is meant from the notation - is because this would destroy every proof that 1 = 0.9...
There is no other reason to disallow this notation.
But let's look at 1 / 3 seeing this is one of the simpler proofs used (although all proofs no matter how cool they look ultimately are just re-representations of this simplest proof).
Let's work it out:
1. 3 ) 1 (can't do)
2. 3 ) 1.0 = 0.3 r 0.1 (as 0.3 x 3 = 0.9)
3. 3 ) 1.00 = 0.33 r 0.01 (as 0.33 x 3 = 0.99)
4. 3 ) 1.000 = 0.333 r 0.001 (as 0.333 x 3 = 0.999)
5. 3 ) 1.0000 = 0.3333 r 0.0001 (as 0.3333 x 3 = 0.9999)
and we could attempt to keep going for ever.
And in all respects each of these answers is correct on its own.
ie 1/3 = 0.3 r 0.1 = 0.33 r 0.01 = 0.333 r 0.001 etc.
The one thing that we can clearly see from the above is that we always have a remainder. The disappointing thing is that the maintainers of the 1 = 0.9... "proof" want us to simply let that remainder drop off the edge of the universe and to just forget about it.
I know I will never be able to convince you but I do have a question that perhaps you can help me with:
Why is it so important to mathematics that 1 = 0.9...?
What is at stake?
Thanks
  • #112
Integral
Staff Emeritus
56
Hi Integral
Let's work it out:
1. 3 ) 1 (can't do)
What is at stake?
Thanks
Once again infinity is NOT a very large real number. That is the way you treat it and that is why you are being fooled into thinking you are doing math.
  • #113
612
Hi Integral
Please state a well defined definition of what "0.0...1" means and show that it is a real number. If you do this im fairly certain everyone will let you use it in this discussion.
What is at stake?
I believe completeness is at stake.
  • #114
376
Hi Integral
Is the following math correct or wrong?
1 / 3
= 0.3 r 0.1
= 0.33 r 0.01
= 0.333 r 0.001
  • #115
1,074
Hi Integral
1 / 3
= 0.3 r 0.1
= 0.33 r 0.01
= 0.333 r 0.001
It is correct, but behavior after a finite number of steps does not dictate the behavior at infinity, certainly not in the way you are treating it.
  • #116
arildno
Dearly Missed
9,970
134
[tex]\frac{1}{3}=0.3+\frac{1}{30}=0.33+\frac{1}{300}=0.333+\frac{1}{3000}=0.3333+\frac{1}{30000}[/tex]
and so on.
Seems you didn't know what division and remainders was after all.
  • #117
Hurkyl
Staff Emeritus
It's not. It's a rather uninteresting consequence of
(1) the axioms of the real numbers
(2) the definition of decimal representations of real numbers
  • #119
218
I touched this topic before, here it goes again for you: let's solve X/10 + X/100 + X/100 + ... to some N/M. we will plug X=9 in then and see If N = M. so. above series sum is X * (1/10 + 1/100 + 1/1000 + ...)
expression in () is infinite geometric progression with a = r = 0.1, hence the sum is 0.1/(1-0.1)
which yields N = K * 0.1 * X, M = K * (1 - 0.1)
for X = 9, N = K * 0.9, M = K * 0.9
so N = M
  • #120
lot of unrelated chatter which doesn't really answer the real question...ie 1/9 = 0.11111... so is 1 = 0.9999999.....?
Now as there are infinite numbers between 0 & 1, and suppose an insect is moving on a table...it starts at point zero and starts moving at a constant speed...so now it covers 0, 0.00000000...1, this last '1' no one knows when it comes...!! now you come back after one hour and see where the insect is..definitely it would have moved,say 10cm. Now how did the insect cross infinite numbers and reach '1' cm and so on till '10' cm????
  • #121
HallsofIvy
41,833
963
Hi Integral
Let's work it out:
1. 3 ) 1 (can't do)
And each of those can be written
2. 0.3+ .1/3
3. 0.33+ .01/3
4. 0.333+ .001/3
5. 0.3333+ .0001/3
Now what is the limit of that fraction as the number of 0s goes to infinity?
Do you understand what each of decimal notation MEANS? The basic decimal notation: 0.a1a2a3... MEANS the limit of the sequence 0.a1, 0.a1a2, a1a2a3, ... (the limit of the sequence, not the sequence itself. If you disagree with that, you disagree with the basic definition of a 'base 10 numeration system'!). We don't need to "attempt to keep going for ever", anyone who has taken enough "precalculus" to have seen geometric series should know exactly what the result is.
A geometric series: the sum of a finite number of terms of the form a+ ar+ ar2+ ...+ arn can be shown to be equal to
[tex]\frac{a- r^{n+1}}{1- r}[/tex]
and, in the case that -1< r< 1, the sequence, as n goes to infinity, has limit [tex]\frac{a}{1-r}[/tex]
While very few decimal sequences correspond to geometric series, the ones here do. 0.333... is DEFINED as the limit of the sequence .3, .33= .3+ .03, .333= .3+.03+.003, .3333= .3+ .03+ .003+ .0003, ... , a geometric series with a= 0.3 and r= .1< 1. The limit of that sequence is
[tex]\frac{0.3}{1- .1}= \frac{0.3}{.9}= \frac{1}{3}[/tex]
Similarly, 0.999.. is DEFINED as the limit of the sequence .2, .99= .9+ .09, .999= .9+ .09+ .009, .9999= .9+ .09+ .009+ .0009, ..., a geometric series with a= 0.9 and r= .1< 1. The limit of that sequence is
[tex]\frac{0.9}{1- .1}= \frac{0.9}{0.9}= 1[/tex]
The one thing that we can clearly see from the above is that we always have a remainder. The disappointing thing is that the maintainers of the 1 = 0.9... "proof" want us to simply let that remainder drop off the edge of the universe and to just forget about it.[\quote]
The remainder "drops of the edge" only if you do not understand that the number represented by a decimal sequence is the limit of that sequence and not the sequence itself!
What is at stake?
Thanks
It is as important as 1+ 1= 2 or any other equation! There is nothing "at stake" except for the people who make such mistakes. Unfortunately, mathematicians have this compulsion to keep trying to correct mistakes about mathematics!
  • #122
Hurkyl
Staff Emeritus
Fortunately, we invented the subject of mathematics a few thousand years back, so we don't have to put up with uselessly vague arguments like this.
Since we've got several people who have appeared from the woodwork to spread misinformation, thread closed.
Related Threads on A shorter proof to 0.999 = 1
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
