Velocity of Striking Ball After Collision: Billiard Ball Physics Problem
  • Thread starter ken62310
  • Tags
    Momentum
In summary, the problem involves a billiard ball moving at a velocity of 4i+3j m/s colliding with a stationary ball of the same mass. After the collision, the struck ball moves at a speed of 4m/s at an angle of 30 degrees with respect to the line of original motion of the striking ball. To find the velocity of the striking ball after the collision, the angles and velocities of both balls need to be taken into consideration. However, if the collision is perfectly elastic and kinetic energy is conserved, the velocity of the striking ball after collision will be 3 m/s, and the two balls will move perpendicular to each other. Using the conservation of momentum equation, the final velocity of the striking
ken62310
PHYSIC momentum QUESTION~
A billiard ball moving with velocity 4i+3j m/s strikes a stationary ball of the same mass. After the collision the struck ball moves with a speed of 4m/s at an angle of 30 degree with respect to the line of original motion of the striking ball. Find velocity of the striking ball after collision.
Pi=Pf
P=mv
Pxi=mv1=4
Pxf=mv2cos(theta)+m(4)cos30
Pyi=mv1=3
Pyf=mv2sin(theta)+m(4)sin30
am i correct with that?? i am really confuse
You have the right idea, however the problem says that the stricken ball goes at a 30 degree angle with respect to the stricker's original line of motion, so you will want to add the two angles.
i am not quite understand what you mean.
how do i add the two angles? could you be more detailed?
Well, let me preface this by saying that what I am telling you is only one approach. I can think at least one other reasonable way to do this problem, however, what I am telling you is pretty straightforward, or at least hopefully it will seem that way.
So if I am walking along some path at 50 degrees and then the path forks off so that one trail goes at 30 degrees with respect to the original direction I am walking, what is the total angle that I have changed by? It would be 80 degrees, right? The same is true for your ball. The first ball has some trajectory with an angle (that I'll let you find), and then it deviates from the angle by an additional 30 degrees.
so that means i need to find the angle that formed by the 4i+3j right?
now i have another question.
I found that the angle of the 4i+3j would be 37 degree.
and for x i will add that to the 30 degree right. then what about for the y?
do i need to add the different angle? should it be respect to the y-axis?
for x: mv1=mv2 cos67+ mv3 cos theta.
for y: mv1=mv2 sin30+ mv3(37-theta).
please tell me if i am correct..
Why mv1? If you projected it to the x-axis, it should have a cosinus in it. Am I missing something?
oh...so for x: mv1 cos 37 and for y: mv1 cos 53 ? am i right?
Initial velocity of the striking ball is 5 m/s. If the collision is perfectly elastic KE is conserved. Since masses of the balls are same V^2 = V1^2 + V2^2. Therefore the velocity of the strking ball after collision will be 3 m/s. And the two balls will move perpendicular to each other.
so all the angle stuff are useless in this case??
It depends on what you have learned so far in physics. If you don't know about kinetic energy and perfectly elastic collisions then conservation of momentum is the only choice you have. Anyway, for the momentum case you should get something to the effect of
[tex]v_{xi1} = 4 = v_{xf1} + 4cos(arctan(3/4) + 30)[/tex]
and
[tex]v_{yi1} = 3 = v_{yf1} + 4sin(arctan(3/4) + 30)[/tex]
so
[tex]||\vec{v}|| = (v_{yf1}^2 + v_{xf1}^2)^{(1/2)}[/tex]
I have a question of my own.
How do you find the angle of the first ball after the collision?
Here is my attempt:
x: m.vi1.cos37 = 4 = m.vf1.cosx + m.vf2.cos7 and vf2 = 4
y: m.vi1.sin37 = 3 = m.vf1.sinx + m.vf2.sin7
Two parameters vf1 and x.
vf1 is the final velocity. (absolute)
x is the angle between the first ball after collision and the x axis.
I find it odd that I didn't use the equation of kinetic energy, there has to be something wrong...
Momentum
If you take the direction of the initial velocity as axis of reference, the problem becomes easy. If you shift the co-ordinate of the initial velocity to the point of impact without any rotation, the components of final velocities of two balls involve several angles. Angle of V1 with new X-axis will be 37 +30 degree. But the angle of V2 with new X-axis is unknown.. If you use coservation of energy we can avoid all these complication.
I didn't understood mindscrape's equations. vxf1 is not in the direction of x-component of the initial velocity and y-component should be the difference of two components of v1 and v2 along y axis.
What is momentum?
Momentum is a measure of the quantity of motion an object has. It is calculated by multiplying an object's mass by its velocity.
How is momentum conserved?
Momentum is conserved in a closed system, meaning that the total momentum before a collision or interaction is equal to the total momentum after the collision or interaction.
What is the equation for calculating momentum?
The equation for calculating momentum is p = m * v, where p is momentum, m is mass, and v is velocity. The unit for momentum is kilogram meters per second (kg m/s).
How does momentum affect an object's motion?
An object with a larger momentum will be harder to stop and will require more force to change its direction or speed. This is why a heavier object moving at the same speed as a lighter object will have more momentum.
Can momentum be negative?
Yes, momentum can be negative. This can happen when an object is moving in the opposite direction of a chosen reference point. For example, if a car is moving west and the reference point is east, the car's momentum will be negative.
