A simple nonlinear ode
  1. Mar 28, 2012 #1
    A "simple" nonlinear ode
    Hi
    Does anyone see a way to solve/approximate this ODE?
    dy'=exp(-f(t)y) with y(0)=yo
    f(t) can be as simple as c*t^3/2 but it may be more complex. This came out as the solution of a very complex problem. This is the final threshold.
    Thanks,
    Donifan
  3. Mar 28, 2012 #2
    phyzguy
    Re: A "simple" nonlinear ode
    You might try using successive approximations, as follows:
    [tex]y_1(t) = y0[/tex]
    [tex]y_2(t) = y0 + \int_0^t e^{-f(t')y_1(t')}dt'[/tex]
    [tex]y_3(t) = y0 + \int_0^t e^{-f(t')y_2(t')}dt'[/tex]
    [tex]y_4(t) = y0 + \int_0^t e^{-f(t')y_3(t')}dt'[/tex]
    And so on. If f(t) is well behaved, this can converge fairly quickly.
  4. Mar 28, 2012 #3
    I believe your y0 should be [itex] y_{n-1}(t) [/itex] when writing out the equation for [itex] y_n(t) [/itex]
    I assume you're doing Picard iteration?
  5. Apr 2, 2012 #4
    Thanks for the suggestion. However even for the simple case of f=t^3/2, y_2 is already a nasty function. I'll keep trying.
  6. Apr 2, 2012 #5
    phyzguy
    Do you need an analytic solution, or is a numerical integration adequate? For your t^3/2 case, the successive approximations converge after 2-3 iterations if you do the integrations numerically.
  7. Apr 2, 2012 #6
    I like Serena
    For a numerical approximation you can typically use Runge-Kutta.
  8. Apr 2, 2012 #7
    Sorry about the confusion. Yes, I am looking for an analytical solution/approximation. I agree the numerical solution is actually simple. Thanks!
  9. Apr 2, 2012 #8
    I like Serena
    You've got me confused at "analytical approximation"... what is that?
    An analytical solution gets very complex in a hurry.
  10. Apr 2, 2012 #9
    Analytical approximation would be something like a solution of a different but related problem, so the order of the error can be estimated.
    I know. The analytical solution by the Picard method is pretty much impossible.
    Maybe there is no solution however the equation seems so simple a compact that you almost feel there should be substitution/trick that quickly solves it, at least for f=c t^3/2.
    Thanks.
  11. Apr 2, 2012 #10
    I like Serena
    Can't you also estimate the error with Runge-Kutta?
    How would any analytical approximation, like Picard's method I guess, be better?
  12. Apr 2, 2012 #11
    The answer is simple: time. An analytical approximation is faster. The solution is suppose to be part of a humongous code that cannot spare a microsecond.
    P.S. When I said error, I meant from the approximated analytical solution to the actual solution.
  13. Apr 2, 2012 #12
    phyzguy
    How about this: Even faster than an analytic solution is a look-up table. Given f(t), solve the equation numerically, then build a look-up table with interpolation that returns y given t. This is typically quite fast. Can this work? Is f(t) a given, or is f(t) constantly changing?
  14. Apr 2, 2012 #13
    The form of f(t) is
    [itex] f(t) = (a^{2} +b t)^{3/2} - a^3 [/itex]
    a and b are constantly changing. The simplest case is a=0. In principle a look up table would work, but I was wondering if a more elegant solution can be reached.
    Thanks.
  15. Apr 2, 2012 #14
    Just realized there is a typo (there is a d before y' that is no suppose to be there). So the whole problem is
    [itex]y'=\exp[-f(t)y][/itex] with [itex]y(0)=y_0[/itex]
    and
    [itex]f(t) = (a^{2} +b t)^{3/2} - a^3[/itex]
    Thanks.
