A simple question
DeathKnight
73
This is an actual question from the past papers. The question is:
It is stated that many forms of transport transform chemical energy into Kinetic energy. Explain why a cyclist traveling at content speed is not making this transformation and explain what transformations of energy are taking place.
I can’t understand why the cyclist is not making this transformation. His K.E. is constant and so is his Gravitational potential energy. But to travel at constant speed he must overcome the resistive forces i.e. energy is being continuously used to work against resistive forces. So that means the chemical energy(which came from the food he ate) is being converted into heat energy(respiration) which is being converted into mechanical energy of the cyclist which in turn is being converted into K.E. of the cyclist and the cycle and also into heat energy. Therefore ultimately the transformation chemical to KE is taking place. Please tell me where I went wrong.
Thanks in advance for any help that you guys can offer
:approve:
Answers and Replies
Antiphon
1,683
You did not go wrong. The problem was probably intended to neglect the forces
of friction and wind resistance.
It should be added that the cyclist would be on level ground.
LeonhardEuler
Actually, he is not converting his energy into kinetic energy, since his speed reamains constant. When he pedals he is turning chemical energy into the heat that is dissipated by friction and air resistance. The only time when the cyclist converts chemical energy into kinetic energy is when he speeds up. I don't believe the problem intended to neglect friction and air resistance.
Suggested for: A simple question
  • Last Post
  • Last Post
  • Last Post
