A simple waveform help please
  • Thread starter ACLerok
Answers and Replies
OlderDan
3,021
ACLerok said:
http://www.rfcafe.com/references/electrical/images/period5.gif
For the last waveform in the picture above. How would i go about writing an equation for f(t)?
Thanks in advance
As an absolute value of something, or as a piecewise definition for each of the intervals that has a continuous derivative.
ACLerok
194
I'm sorry i do not follow. I understand if it was just a ramp function it would just be (Vm/T) t but i still don't know
OlderDan
3,021
The last waveform is called a Full-wave rectified sine. It is a sine function with all the negative regions flipped to positive. It is the absolute value of the sine function
[tex] f(x) = \left| {A\sin 2\pi \frac{t}{T}} \right| = A\left| {\sin 2\pi \frac{t}{T}} \right| [/tex]
or you could write separate functions for the separate intervals with alternating plus and minus signs in front of the sine function.
ACLerok
194
i see.. so am i correct to say that the equation for f(x) for the third waveform would be Asin(4pi/T)?
OlderDan
3,021
No. For one thing you need a variable, t, in the argument of the sine function (T is a constant) and you need to define the function to be zero in the intervals where the waveform is zero. One way to do that would be to take 1/2 times your second waveform and add A/2 so that the square wave is between 0 and A; then use that in place of the A in the sine function you have.
ACLerok
194
for the full rectified sine wave, the equation for f(t) from 0 to T/2. can it not have a sin in the equation maybe something like A(1-t^2)? (i know that's incorrect)
ACLerok
194
anyone? :(
OlderDan
3,021
I'm not sure what you are asking. For the full-wave rectified sine the function is a sine function from 0 to T
[tex] f(x) = A\sin \pi \frac{t}{T}} [/tex]
Between T and 2T it is
[tex] f(x) = -A\sin \pi \frac{t}{T}} [/tex]
There is no 1-t^2 involved
OlderDan
3,021
CORRECTION!
Sorry, I misinterpreted the T as being the period of the sine function. In fact 2T is the period in the figure. This should have been
[tex] f(x) = \left| {A\sin \pi \frac{t}{T}} \right| = A\left| {\sin \pi \frac{t}{T}} \right| [/tex]
OlderDan
3,021
From 0 to T/2 or from nT to (n+1/2)T this should be
[tex] f(x) = {A\sin 2\pi \frac{t}{T}} [/tex]
From T/2 to T or from (n+1/2)T to (n+1)T f(x) is zero.
Suggested for: A simple waveform help please
  • Last Post
  • Last Post
