Does the block move along the pink dotted lines
In summary, the conversation is discussing a problem where a small block is projected from the bottom of a fixed sphere with a certain speed, causing it to move in a vertical circular path. The questions to be answered include finding the speed of the block as a function of the angle of deflection from the lowest vertical, the normal reaction when the vertical component of the block's velocity is maximum, and the angle between the thread and the lowest vertical when the total acceleration vector of the block is directed horizontally. The suggested approach involves using mechanical energy conservation and drawing a free body diagram for the block's path. The conversation also addresses issues with the initial diagram and provides a hint for solving the problem.
Kaushik
282
A small block ##m## is projected with speed ##v_0 = \sqrt{2gR}## from bottom of a fixed sphere of radius ##R## , so that the block moves in a vertical circular path.
Attached below.
Does the block move along the pink dotted lines as attached in the figure below?
I tried to draw the FBD of the small block ##m ## at the lowermost point which is also attached below.(The direction of ## v_0 ## is actually tangential)
Is the figure above correct? If not, why?
Kaushik said:
Problem Statement: A small block ## m ## is projected with speed ## v_0 = √2gR ## from bottom of a fixed sphere of radius ##R## , so that the block moves in a vertical circular path.
Relevant Equations: Attached below.
Your diagram is fine for the initial motion, but the speed will drop as the block rises. What exactly is the question to be answered? You probably need an FBD for a more general position.
Likes Kaushik
The questions to be answered are -
i) The speed of the block as a function of ## Θ ##, where Θ is the angle of deflection from the lowest vertical.
ii) Normal reaction when the vertical component of the block's velocity is maximum.
iii)The angle between the thread and the lowest vertical at the moment when the total acc. vector of the block is directed horizontally.
I didn't write these questions before as I wanted the image.Like, I wanted the intuition of how this system really looks.
Thanks.
Thanks.
Then, as I posted, you need to draw the FBD and write equations for the general position, as described in (i).
Don't bother trying to draw perspective, as you seem to have done in post 1. Just show the plane in which the block moves.
Likes Kaushik
What does the above line mean? Should I assume that the block lies at an angle theta from the lowest point?
The diagram does not look correct. Since the initial velocity is tangent to the circle, the block will start sliding on the inside surface of the circle, presumably without friction. The questions to consider are, will the block slide all the way up to the "12 o'clock" position or will it fall off at some intermediate point and, if so, where is that point and what is the subsequent path of the block?
Likes Kaushik
We know that the velocity decreases as the angle theta increases because of ## g ##. Can we find the velocity of the block as a function of theta? If yes, can I get a hint?
The "lowest vertical " means the radius line from the centre of the circle to the bottom of the circle. Take another radius line from the centre of the circle to the block and call the angle between the two radii theta,
Draw the FBD for that.
Likes Kaushik
Hint: Mechanical energy conservation plus a free body diagram. I assume the question to be answered is "Draw the complete path of the block inside the shell."
Likes Kaushik
Anything conserved?
Likes Kaushik
Using your hint, i found ##V(Θ) = √(2gRcosΘ)##
Thanks a lot.
Thanks a lot.
Is that what you were looking for?
Likes Kaushik
Apart from that, I have 2 more questions to solve.
These are the remaining questions I need to solve.
This happens when the angle is 90 right ?
Look at your expression for ##V(\Theta)##. At what angle does it have a maximum?
Likes Kaushik
I meant 0.
Kaushik said:
I meant 0.
Good. Now draw a free body diagram of the block wjen it is at ##\Theta=0##. However, before you do that count how many items outside the block exert a force on it. You should draw as many forces acting on the block as you have items interacting with it. Also, draw the acceleration of the block outside the FBD.
Likes Kaushik
kuruman said:
Good. Now draw a free body diagram of the block when it is at ##\Theta=0##. However, before you do that count how many items outside the block exert a force on it. You should draw as many forces acting on the block as you have items interacting with it. Also, draw the acceleration of the block outside the FBD.
The forces I noticed are - Normal Force( Centripetal force here), Weight.
That's it, good job. Now what do you think you should do next? What's the purpose of drawing a free body diagram?
Likes Kaushik
Now should I equate ## F_{net} ## to centripetal acceleration? Is it ## N = 3mg ##?
Yes and yes.
I stand corrected. I misread the question. See post #34 by @jbriggs444 who has a knack for keeping me honest.
Likes Kaushik
kuruman said:
Yes and yes.
Thanks a lot for your help.
You are welcome. Can you finish the problem now and answer the third question?
Likes Kaushik
Yes.
Likes kuruman
Kaushik said:
Now should I equate ##F_{net}## to centripetal acceleration? Is it ##N=3mg##?
No and no.
##F_{net}## is only equal to [mass times] centripetal acceleration if tangential acceleration is zero. The vertical component of the block's velocity will not be maximized at the bottom of the circle.
Likes kuruman and Kaushik
jbriggs444 said:
No and no.
If not at the bottom, where else?
You have speed as a function of angle. What is the vertical component of velocity as a function of angle?
Likes Kaushik
Can I get a hint?
Kaushik said:
Can I get a hint?
Umm, it is pretty simple. If you know how fast something is moving and in what direction it is moving, surely you can figure out the vertical component of that motion.
Likes Kaushik
So the direction is tangential. So I have to find its vertical component.
I'll try again, yes. But first you have to find the speed.
Likes Kaushik
  • #31
But we found speed to be ## V_0 = √(2gRcosΘ) ## . Isn't?
  • #32
We have the speed: ##\sqrt{2gR\cos \theta}##
We have the angle of the perpendicular: ##\theta##
  • #33
Is ## V\sin{\theta}## the vertical component?
Likes jbriggs444
  • #34
Yup. So now you have the hard part. Finding a maximum for an ugly looking formula. I do not see an easy approach short of trial and error. Finding the maximum by taking the derivative and solving for a zero does not look good. Maybe @kuruman has some algebra trick up his sleeve.
Likes Kaushik
  • #35
I was trying to differentiate it and solving it for zero.
Ok I'll wait for @kuruman to reply.
