Is the speed of one beam in the LHC nearly twice that of the other?
  • Thread starter pixel01
  • Tags
    Lhc
In summary, the Large Hadron Collider (LHC) has just started with two beams of protons traveling in opposite directions at nearly the speed of light. The speed of one beam compared to the other is 2c just before collision, but this does not violate relativity as no thing is actually traveling at that speed. The "closing speed" is used to describe the rate at which the distance between the beams decreases. If one beam is considered the frame, the other would be traveling at a speed of 2c. This can be calculated using the formula (u+v)/(1+uv/c^2), where u and v are the speeds of the two beams relative to the ground.
pixel01
688
Hi all,
I've learned that the LHC has just started. There are two beams of protons which travel clockwise and anti-clockwise at nearly the speed of light. Then the two beams are to colide into each other. My question is whether the speed of one beam compared to the other is at nearly 2 c ?
Yes the closing speed is 2c, if you were traveling with one bunch of particles you would measure the other bunch approaching you at c (although what you would measure this with - I'm not sure)
This doesn't violate relativity in any way, no THING is traveling at 2c, just the rate of decrease of the distance between them.
The speed of one beam wrt other is 'c'. NOT 2c
Just before collision, the coordinate distance in the frame of the Earth between bunches of particles traveling in opposite directions decreases at the rate of (nearly) 2c. This is what mgb_phys meant by "closing speed."
So if one man stood on one beam, he would see the second moving at 2c ?. In other way, one beam would travel at 2c if the other beam was considered the frame?
If the speed of one beam is u and the speed of the other v (both relative to the ground), then the speed of one of the beams relative to the other is
[tex]\frac{u+v}{1+uv/c^2}[/tex]
For example, if u=v=0.99c (exactly), then the result is (0.99+0.99)c/(1+0.99*0.99)=0.99994949750012... c.
1. What is the LHC?
The LHC, or Large Hadron Collider, is the world's largest and most powerful particle accelerator. It is located at the European Organization for Nuclear Research (CERN) in Switzerland and is used by scientists to study the fundamental building blocks of matter and the laws of nature.
2. How does the LHC work?
The LHC works by accelerating particles, such as protons or lead nuclei, to nearly the speed of light and then smashing them together. This creates high-energy collisions that allow scientists to study the resulting particles and their interactions.
3. What is the purpose of the LHC?
The main purpose of the LHC is to help scientists better understand the fundamental laws of nature and the origins of the universe. It also has potential applications in fields such as medicine and technology.
4. What are some of the discoveries made at the LHC?
One of the most significant discoveries made at the LHC was the confirmation of the Higgs boson particle in 2012, which is responsible for giving other particles mass. The LHC has also provided evidence for the existence of dark matter and has allowed scientists to study the behavior of matter at extreme temperatures and densities.
5. Are there any potential risks associated with the LHC?
The LHC has been extensively studied and deemed safe by multiple scientific bodies. However, there are some concerns about the production of mini black holes or strangelets, but these risks have been deemed extremely low. The LHC also has strict safety protocols in place to mitigate any potential risks.
