A Static friction problem
  1. Oct 27, 2005 #1
    I was working the following problem:
    Two blocks rest on a horizontal frictionless surfce (the top block being 5kg and the bottom block being 10 kg). The surface between the top and bottom blocks is roughened so that there is no slipping between the two blocks. A 30 N force is applied to the bottom block ( a 30 N horizontal force). What is the force of static friction between the top and bottom blocks
    The answer key tells me that the answer to the problem is 10 N. I know that fsMAX = coefficednt of static friction * FN. I figured that the normal force for the top block is 49 N and the bottom block is 147 N. I can't figure out what combination of those numbers equal 10 N. Any help would be appreciated.
  3. Oct 27, 2005 #2
    Doc Al
    Staff: Mentor
    Hint: Find the acceleration.
  4. Oct 27, 2005 #3
    Re
    I know the acceleration is 2m/s, but I'm still a little loss. Do I just take into account the top block and say that since F=ma that fs=ma thus fs = (5kg)(2m/s^2)? If that is the answer, why just use the 5kg top block and not both the 5kg block and 10kg block?
  5. Oct 27, 2005 #4
    Doc Al
    Staff: Mentor
    That's the answer. To analyze the forces acting on the top block (such as the friction), apply Newton's 2nd law to the top block. (If you apply Newton's 2nd law to both blocks you will not learn anything about the friction between the blocks since, due to the third law, the net friction force on both blocks is zero.)
  6. Oct 27, 2005 #5
    Re
    Thank you :smile:
