A stick falls.
  1. Feb 3, 2014 #1
    Mod note: deleted image that was way too large.
    I want to know the time flowed while the stick falls.
    gravity = g
    density of the stick is same so it's center of mass is l/2.
    what is the T?
    2. Relevant equations
    3. The attempt at a solution
    failed to do torque.
  3. Feb 3, 2014 #2
    Simon Bridge
    You mean - "how long does it take for the stick to fall?"
    Is the point of contact a fixed pivot?
    ... then learn.
    The subject requires an actual physics lesson - there is no shortcut - lessons are expensive for a reason.
    You need to draw the forces into the diagram.
    At the center of mass, gravity creates a torque.
    Torque is the perpendicular component of the force times the distance.
    In your case, the torque will depend on the angle.
    The equation to solve is ##\sum\tau = I\ddot\theta## ... so you need to know about angular momentum as well. For the stick, pivoted about one end, ##I=mL^2/3## - where L is the length of the stick.
Have something to add?
Draft saved Draft deleted
Similar Discussions: A stick falls.
  1. Falling stick (Replies: 1)
  2. A stick falls. (Replies: 4)
  3. Falling stick (Replies: 22)
Loading...
