A strange fortran code
  • Fortran
  • Thread starter phynewb
Main Question or Discussion Point
Hi guys,
I just wrote a simple code for delta function and print it out. Here it is.
Code:
      program main
        implicit none
        integer i
        real*8 del
        real*8,parameter:: ep=1D-2
        real*8,parameter:: pi=3.1415926
        do i=-10,10,1
        write(*,*) i,del(real(i))  ! use function
        enddo
        do i=-10,10,1
        write(*,*) i,(1.0/pi*ep/((real(i))**2+ep**2)) ! no use function
        enddo
        end
      function del(x)
      implicit none
      real*8 del
      real*8 x
      real*8,parameter::ep=1D-2
      del=(1.0/pi*ep/(x**2+ep**2))
      return
      end
It turns out to be quite wrong by using function del. I cannot figure out what's wrong with the function because the expression is the same. Can you tell me how to debug the function? Thanks!
Answers and Replies
4,858
Hi guys,
Code:
      program main
        implicit none
        integer i
        real*8 del
        do i=-10,10,1
        enddo
        do i=-10,10,1
        enddo
        end
      function del(x)
      implicit none
      real*8 del
      real*8 x
      return
      end
What output do your two loops produce?
It shows
-10 31.830990148286446
-9 4.42379935910539249E-054
-8 3.96072696157977595E-306
-7 31.830990148286446
-6 4.42379936653263965E-054
-5 0.0000000000000000
-4 31.830990148286446
-3 4.42379937841623373E-054
-2 0.0000000000000000
-1 31.830990148286446
0 4.42380394766179441E-054
2 4.42380242655975552E-054
3 31.830990148286446
4 4.42380241467614869E-054
5 31.830990148286446
6 4.42380240873434528E-054
8 4.42380240279254245E-054
9 31.830990148286446
10 4.42380239982164045E-054
-10 3.18309583173281331E-005
-9 3.92974701861929112E-005
-8 4.97358443944407051E-005
-7 6.49610718106421125E-005
-6 8.84191714697638248E-005
-5 1.27323451299340604E-004
-4 1.98942445036508832E-004
-3 3.53673738606087140E-004
-2 7.95754859835665312E-004
-1 3.18278073675496917E-003
The upper part is from the function and the lower part is calculated without function. It shall look like sharp gaussian distribution around 0 instead of random distribution.
4,858
I'm pretty sure this line is causing the problem:
Code:
In the call to your del function, you are converting an integer value, i, to a four-byte real (a single-precision floating point value), but the function is expecting an eight-byte real (a double-precision floating point value).
I think this will fix the problem:
Code:
write(*,*) i,del(dble(i))  ! use function
Here's a link to a page with more information - http://www.liv.ac.uk/HPC/HTMLF90Course/HTMLF90CourseNotesnode114.html [Broken].
Code:
Code:
Thanks Mark44. It really works! I am always troubled by this accuracy stuff...
Thank you a lot :p
4,858
It's more about the size, in bytes, of the variables you're using. For floating point variables, the choices are real*4 (single precision - 4 bytes) and real*8 (double precision - 8 bytes). real() converts whatever to a 4-byte floating point value and dble() converts whatever to an 8-byte floating point value.
Make sure that what you pass to a function is what it is expecting - otherwise you'll have problems.
Related Threads for: A strange fortran code
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
