A thermodynamics problem
  1. Aug 3, 2010 #1
    [PLAIN]http://img101.imageshack.us/img101/7498/thermo.jpg [Broken]
    A cylinder is closed by a massless piston of cross sectional area A which is connected to a spring of constant k. With the spring relaxed, the cylinder is filled with a gas. The initial pressure, volume and temperature are Pi Vi and Ti. How high will the piston rise if its temperature is increased to a final value of Tf?
    2. Relevant equations
    3. The attempt at a solution
    I tried to find Pf and Vf.
    Pf = Pi + kx/A
    Vf = Vi + Ax
    I then wrote the universal gas law for Pf Tf and Vf but I doubt this is correct because the equation was crazy long and complicated.
  3. Aug 3, 2010 #2
    ehild
    In spite of being crazy long ad complicated, it might be correct. There were no numerical data?
    ehild
  4. Aug 3, 2010 #3
    Nope, only letters. Are the expressions I wrote for Pf and Vf correct?
  5. Aug 3, 2010 #4
    Andrew Mason
    You have written out the expression for the pressure as a function of x and volume as a function of x. All you have to do is relate that, using the ideal gas law, to the change in temperature.
    AM
  6. Aug 3, 2010 #5
    ehild
    I think they are correct. But the expression for x will be really ugly. Just go ahead.
    ehild
  7. Aug 3, 2010 #6
    That gives a quadratic equation:
    kx2 + (PiA + kVf/A)x + nR(Ti-Tf) = 0
    I highly doubt this is the correct answer because this is an old exam question and impossible to do in ~10 minutes.
  8. Aug 3, 2010 #7
    ehild
    Well, it is not quite correct, there should be Vi instead of Vf in your term kVf/A. And you should replace nR by piVi/Ti.
    Then use the formula for the solution of quadratic equations and exclude the negative root. It takes less time than 20 s.
    ehild
