- #36
- 10,300
- 1,467
hover said:Hey everyone,
speaking of time dilation what equation can predict how slow a clock will run when it is accelerated??
thanks!
If you are at the same location as the clock, neither the clock's acceleration or your acceleration will matter.
I believe there is a sci.physics.faq entry on this, if I find it I'll edit this post to enter it later.
[add]
The physics FAQ on this topic is at http://math.ucr.edu/home/baez/physics/Relativity/SR/clock.html
I'll give a short excerpt and encourage hoover and other interested parties to read the original in its entirety.
The clock postulate can be stated in the following way. First, we take the rate that our frame's clocks count out their time, and compare that to the rate that a moving clock counts out its time. Before the clock postulate was ever thought of, all that was known was that when the moving clock has a constant velocity v (measured relative to the speed of light c), this ratio of rates is the Lorentz factor
gamma = 1/sqrt(1-v2)
The clock postulate generalises this to say that even when the moving clock accelerates, the ratio of the rate of our clocks compared to its rate is still the above quantity. That is, it only depends on v, and does not depend on any derivatives of v, such as acceleration. So this says that an accelerating clock will count out its time in such a way that at anyone moment, its timing has slowed by a factor (gamma) that only depends on its current speed; its acceleration has no effect at all.
