Gravitational Time Dilation: A Thought Experiment
In summary: In the case of the Schwarzschild solution, however, since the gravitational field alters the distance between clocks, it would seem that the frequency shift should be a result of the gravitational field, not the clock itself. How might one distinguish between these two cases?It's easy to see why an observer located at the position of the higher clock will conclude that the lower clock ticks slower in the case of an accelerating rocket - successive pulses transmitted at one second intervals by the lower clock (in the rocket tail) will travel an additional distance to reach the front because the higher clock is moving away from the source so each light pulse must travel further - likewise for the lower clock - pulses transmitted
  • #106
MeJennifer said:
I must be missing something, please bear with me.
Suppose I have one single clock with a simple rocket and some computerized navigation system.
I programmed this system in such a way that the clock will accelerate with a proper constant acceleration and proper time interval and afterwards it will record the time.
Now would that be possible?
Yes, of course.
MeJennifer said:
Assumming it is, suppose I build two of those.
Also possible, in principle!
MeJennifer said:
Now I place one to the left of me and one to the right and make sure I stand in the middle and launch them at the same time.
"In the middle" could be a problem--- let's say the two craft are initially comoving inertial and then all notions of "distance in the large" should agree, and also "at the same time" should be unambiguous.
MeJennifer said:
Then afterwards I fetch each clock and check their times.
Uh oh! First, you didn't specify how the craft accelerate after you begin the experiment. Second, you didn't specify how you try to compare the elapsed times after the craft have executed specified motions. One direct method would be to make them move some more until they are once again comoving inertial, whereupon we can try to check them via Einstein's synchronization procedure, and will presumably find that they are no longer synchronized, according to Einstein's procedure for comparing ideal clocks carried by comoving inertial observers.
Recall what we said about multiple operationally significant notions of distance. Likewise, there are multiple operationally significant notions of comparing times of clocks carried by distant observers.
MeJennifer said:
What exactly is impossible here?
Please reread what I wrote in my earlier two posts, including the sentence you originally wrote, which I quoted and stated was trying to posit an situation which cannot arise in Minkowski geometry. Please try to very carefully draw the Bell and Rindler congruences and their euclidean analogs. I think you will see what I mean if you keep trying.
  • #107
I said constant proper acceleration, see the satement below.
What else would you like to know?
I did. I explained that after a proper time interval the clocks stop counting and that the last recorded time was visible on the display. See the statement below.
Here is what I wrote so you can acknowledge.
Scenario 1
MeJennifer said:
In flat space-time, two completely identical ideal clocks separated by an initial distance l accelerate with a constant proper acceleration a for a proper time interval t. After this time interval each clock stops counting but leaving the final time on their displays.
An observer fetches both clocks and compares the time as displayed on their displays.
Are the readings identical or not?
Scenario 2.
MeJennifer said:
In flat space-time, an arbitrary end of a ridgid rod of a length l is accelerated in the direction of the other side with a constant proper acceleration a for a proper time interval t. Two completely identical ideal clocks were placed at each end of this rod with a built in accelerometer. Each clock is individually programmed to start counting as soon as the acceleration starts and to stop counting as soon as the acceleration stops. Once the clock stops it leaves the final time on its display.
An observer compares the time as displayed on their displays.
  • #108
Sorry, MeJennifer!
Oh no! I see now that I did misread the sentence I quoted in my previous post (italics added and notation slightly modified):
MeJennifer said:
In flat space-time, two completely identical ideal clocks separated by an initial distance d accelerate with a constant proper acceleration a for a proper time interval t.
I thought you wrote:
"In flat space-time, two completely identical ideal clocks separated by constant distance d accelerate with a constant proper acceleration a for a proper time interval t."
Sorry, sorry, sorry! The latter statement, which conflates the Bell and Rindler congruences, is exactly the mistake apparently made by RandallB in arguing with Hurkyl. Because I was trying hard to explain this to RandallB, I misread the crucial word "initial" in your own post. I apologize profusely--- this thread has already seen more than its fair share of misunderstandings, and I regret having unintentionally added to the obscuring smoke when I meant to increase the level of illumination...sigh...
But there is a larger point here. For those who haven't yet grasped the distinction between the Bell and Rindler congruence:
When one says that two craft "accelerate with a constant proper acceleration a for a proper time interval t", one is saying they belong to the Bell congruence (for acceleration of magnitude a in a certain direction). When one says "constant distance l", one is saying they belong to the Rindler congruence (for acceleration in a certain direction while maintaining rigidity). But a pair of leading and trailing observers (with no separation transverse to the common direction of acceleration) can belong to the Bell congruence, or they can belong to the Rindler congruence, but they can't belong to both.
Be this as it may, I have some remaining objections to your scenarios:
1. In your "Scenario 1" you wrote that a third observer "fetches both clocks and compares the time as displayed on their displays", which I understand to mean that a third craft rendevous's with the trailing and then the leading observer, fetching their clocks, and then someone compares them directly inside the cabin of the third craft. If so, you would need to describe exactly how the clocks are moved to bring them together inside the spaceship of the third observer in order to compare them, before this thought experiment would be well defined.
2. In your "Scenario 2" you wrote "In flat space-time, an arbitrary end of a ridgid rod of a length l is accelerated in the direction", but this is also impossible, since "rigid" bodies cannot be accelerated in str, without becoming nonrigid. More precisely, as the Rindler congruence shows, we cannot "rigidly accelerate" a body by pushing at one end; we need to accelerate different bits by different amounts, so that each bit accelerates like a Rindler observer. This would be a highly artificial situation.
  • #109
Jorrie said:
OK, maybe the term uniform gravitational field was a bad choice of words. Let's replace uniform gravitational field with uniform gravitational potential gradient in a specific direction. Now gravitational potential linearly change in that direction, while gravitational acceleration remains constant.
This, IMO, represents the situation of linear acceleration where the "g-meters' on the two clocks, line astern, read the same acceleration, while the gravitational redshift differs. The front clock gains time on the rear clock.
Jorrie
This is the "equivalence" argument Hurkyl referred to in the early posts, I hope he is not still holding to that.
Think through your description here.
Earth has such a "gradient" that is the gravitational potential at the surface is stronger than the potential say a quarter way to the moon. If you had a mountain that tall you would weigh much less there. But you mass has not changed, if you jump down 16 feet can it be done in just one second? How is that smaller force still going to accelerate you at same 32 ft/sec^2 you would have at the surface?
  • #110
That is not neccesary since the clocks stop as soon as the acceleration is done. So we can simply look at the display to verify the recorded time. Just check it I wrote it in the description.
I thought the argument was that in Rindler congruence there would be no stress on the rod while in Bell congruence we would see that the rod tears apart. No?
So you are saying that for instance the commonly used accelerated elevator in space does not show Rindler congruence? Then what does it show, certainly not Bell congruence right?
  • #111
Amusing! The reason I presented the two scenarios in the first place was to an attempt to clear up the confusion, something in which I obviously and miserabily failed. :smile:
  • #112
Oh the humanity! The humanity!
Truly, this is like watching an airship wreck!
The first sentence clearly refers to the Bell congruence (since the leading and trailing observers are said to have the same path curvature). Without knowing exactly how Jorrie intended to compare the time kept by these two observers I can't say whether the second sentence is correct.
The observer riding in spaceship A can check the time kept by the ideal clock carried in ship A, at any event on A's world line. Likewise, the observer riding in spaceship B can check the time kept by the ideal clock carried in ship B, at any event on B's world line. But when one wants to compare the time kept by these two clocks after the two ships have performed some motions, one needs to specify a procedure. Generally speaking, either the two ships will need to "rendevous" so that they are once again comoving inertial (ideally, even share the same world line!), or else they will need to signal to each other somehow. In both cases, the details of the rendevous manuevering or signalsing (respectively) are absolutely crucial.
Yes, although I was using taut strings and trying as far as possible to avoid elastodynamics, the non-Lorentz covariance of Hooke's law and Hookean constitutive relationships, and so on.
Sigh... I confess to tiring of this. I hesitate to say anything until I know exactly what we mean by "the commonly used accelerated elevator in space".
It is probably true that most authors use "uniform field" to mean Rindler congruence, which as we have seen in this thread is potentially confusing. However, it would also be potentially confusing (no pun intended) to use the Bell congruence. A third candidate would be a certain nontrivial Weyl vacuum which happens to be locally isometric to the Minkowski vacuum (take the Newtonian gravitational potential of a uniform mass density ray; the equipotentials look like nested parabolas in a parabolic chart; this generates a Weyl vacuum solution which turns out to be essentially the Rindler vacuum written in a parabolic chart). A fourth candidate would be the Weyl vacuum generated by the Newtonian gravitational potential of a uniform density thin plate, which is not locally flat, but does capture the idea that equipots should be "parallel planes" (because this exact vacuum solution possesses a Lie algebra of Killing vector fields which is isomorphic to e(2), the Lie algebra of the group of planar euclidean isometries).
All of these have multiple properties which are quite different from what one would expect from Newtonian physics. I have written voluminously in the past about the trickiness of "uniform gravitational field" in gtr.
Yes, I surely do know that sinking feeling (no pun intended)...
  • #113
Chris Hillman said:
IMO, you have been consistently rather rude in this thread,
I don't know what you mean by "FO observer",
I'm RUDE!
I've been told to ignore my own thoughts as I'm not the "Science Adviser", even you pass judgments while explaining you just skimmed the material. No one acknowledges that an Earth style gravitational field is not equivalent to a constant acceleration. And when I suggest accelerating the F0 point, defined by Hurkyl as the observation point and frame from which the graphs are constructed, to explain how that would not produce the same exact graphs as moving the clocks. Not only does no one even look at it, you don't know what I'm talking about because, I don't know, I guess you don't like reading his posts.
I see no point in rewriting and posting what is already being ignored, and I can do without the abuse.
So I'll leave this thread and wish Hurkyl good luck. He at least seemed to put some sincere effort and thought into it, maybe he'll get around to consider all angles and either change his mind or find a more complete solution than these two issues have seen to support Bell's ideas. Either way, by that I mean do better than Bell did. I love his Bell Theorem but I just don't see his work here on these two issues as complete.
I'm Done Here.
  • #114
Regarding being "told to ignore my own thoughts", I think you might be misattributing a remark by pervect to myself. I did say that I considered your comment "Wow you are having trouble following the problem" to be a bit rude, as was a remark by another poster (who I won't name), who demanded (of a fourth poster), "Can you read?"
I try to avoid the appearance of making "personal attacks", although this can sometimes be hard to do; no doubt I could have done a bit better myself in this thread, and I apologize if I have offended anyone.
One principle which can be useful: try to choose words which distinguish between criticizing a particular claim made by X, and attacking or being rude to X himself/herself.
For the record, I have no problem reading Hurkyl's posts!
I think you misunderstood why (much earlier) I emphasized that I was only skimming the thread. In the end I did wind up reading a number of posts more carefully than I intended to, but my desire to avoid spending much time on reading more carefully was, perhaps, understandable if you know a bit of background.
I have explained elsewhere (so you might not have seen these remarks) why I am reluctant to discuss the so-called "spaceship and string paradox" any more: I feel that I have paid my dues amply in another forum. (I don't feel that this would really be a very enlightening exercise as far as physics goes, but anyone wishing to verify said payment of dues may skim the archives of http://en.wikipedia.org/wiki/Talk:Bell's_spaceship_paradox and peruse http://en.wikipedia.org/wiki/Wikipedia:Requests_for_comment/Rod_Ball) [Broken].
Er... I just mentioned that very issue! Hurkyl also alluded to it, if I am not mistaken.
My own take is that I tried rather hard to play peacemaker here, and I don't think I "abused" anyone, but I regret that you feel put upon, particularly since, as Chekhov put it, "ninety percent of human misery is based upon simple misunderstanding".
Oh well... let's wrap this thread up by saying that it's terribly important to try hard to make sure everyone is talking about exactly the same thing, which generally requires typing in a lot more mathematics than anyone (including myself) was willing to do here.
  • #115
MeJennifer said:
I am getting interested in accelerating clocks. :smile:
Let me get this absolutely right:
Is that what is claimed?
What you stated is not the problem I was stating about the clocks.
The two-clocks-on-a-uniformly-accelerating-rocket could be explicitly stated in different ways. Probably the simplest is:
(1) We're working in Minkowski space. (which is flat)
(2) It looks the same in any inertial reference frame.
(3) The tail never passes the head.
(4) A light signal emitted from the tail will always reach the head.
From these assumptions, you get a diagram that looks like the first diagram I drew here on the red coordinates.
It also turns out to be true that in this situation:
(5) The proper acceleration of the tail has a constant magnitude.
(6) The proper acceleration of the head has a constant magnitude, which is less than that of the tail.
(7) In any inertial frame, there is an instant when the entire rocket is at rest. At that instant, the coordinate length of the rocket is L. (All inertial frames agree on the value of L)
If we just want to uniformly accelerate for a bit, then stop accelerating, we get a diagram like this:
I've marked proper time on the diagram. (Sorry, I was lazy and stopped marking after the acceleration stopped) The blue line is the extent of the rocket (as measured in what is then the rockets rest frame) that the acceleration stops, and the distance along that blue line is exactly the original length of the rocket.
(Just to emphasize, it is somewhat remarkable that it works out that there exists an inertial frame in which every point of the rocket stops accelerating simultaneously)
As you can see, the rear clock has ticked fewer times than the front clock during the acceleration phase. Additionally, the rear clock has dilated more than the front clock with respect to the red inertial frame, as you can see from the red time coordinate of the third tick of each clock.
The situation you were describing sounds more like you were trying to describe this:
In this picture, both rockets start simultaneously (as measured by the red frame). They both have an acceleration of constant magnitude, and those magnitudes are the same for each. Both rockets shut off after an equal amount of proper time.
As you expected, each rocket reads 4 ticks when it stops. (Of course, in most frames, they did not stop simultaneously) The blue line indicates the instant the tail rocket stops, as measured in the frame in which the rockets eventually come to rest. As you can see, in this frame, the rockets are then very far apart, and that the head rocket reads a much larger time than the tail rocket.
  • #116
RandallB said:
OH, but wait you did give three diagrams from the view of an accelerating point without the clocks or string moving at all.
The same three diagrams you gave for holding the observation point stationary. This must prove that string tied to fixed points will break spontaneously! I’ve put up a sting and am waiting for it to break, but no luck so far. Maybe it means that it won’t break unless some accelerating observer goes by and actually looks at the string and its attachment points! But that would mean the moon is not really there unless someone looks at it, and I don’t buy that view either.
Well, maybe I shouldn't reply since you've said you're done with the thread, but I still think it's worth saying.
The equivalence principle only applies to inertial frames -- the laws of physics in a noninertial frame have a different form than they do in an inertial frame. This is a terrific example of that.
(And, once again, measurements are made relative to a coordinate chart... not relative to a point)
  • #117
RandallB said:
I'm RUDE!
Interesting that Randall describes himself as rude - I would say that he has a 'tude (slang for attitude), but he seems to be reasonably polite, he just doesn't listen very well. (I might even add "if at all".)
Probably my main concern is that third parties recognize that RandallB is "following his own thoughts", as he puts it, as opposed to to, for example, doing his best to represent some "standard view" taken from the literature and the textbooks, with references to sources wherever possible.
I wouldn't particularly suggest that RandallB do or not do anything, except perhaps to abide by PF guidelines (not that I have any complaints in that department). He's simply far too independent for me to wish to offer him any such suggestions.
  • #118
Potential gradient
Hi Randall:
From my side, I sincerely hope that Hurkyl is holding on to that! :wink:
Earth doesn't have a uniform potential gradient, while the hypothetical gravity field with uniform potential gradient in one direction has. So what you said above is not relevant.
Jorrie
