Prasun-rick
- 31
Member warned that homework questions must be posted in the HW & CW sections
∫|x^3-x|dx with limits from -1 to 2.Can anyone kindly show the step wise solution or suggest how to proceed .Thanks in advance
The modulus sign! I In which limit I have to take positive and negative in the modulus I could not understand!Krylov said:Can you tell us first what makes it troubling for you?
Well I am not able to draw precisely and that is where the problem lies !BvU said:First step: make a drawing !
well kindly please tell me the terminal points ! I found it as -1,0 and 1 am I correct??BvU said:Doesn't have to be precise. Simply investigate the function a little.
Where it comes from on the left, where it goes through zero and where it goes to on the right.
Perhaps there is even a little symmetry to explore and make good use of ...
Thanks I finally got that !Thank you very much !BvU said:I don't know what terminal points are but the zero points of ##\ \ x^3-x = x(x+1)(x-1) \ \ ## are indeed -1, 0, 1 .
Between -1 and 0 two out of three factors are < 0 and the other is > 0, so the expression is positive.
Between 0 and 1 ...
There is antisymmetry : ##\ \ (-x)^3 -(-x) = -(x^3 - x) ##, so ...
A definite integral is a mathematical concept used to calculate the area under a curve on a graph. It is represented by the symbol ∫ and has a lower and upper limit, indicating the range of values to be integrated.
A troubling definite integral can be difficult to solve because it may involve complex mathematical functions, require advanced techniques, or have no known analytical solution. In some cases, numerical methods or approximations may be used to solve it.
A troubling definite integral is different from a regular definite integral because it is usually more challenging to solve, either due to its complexity or lack of known solutions. It may also require special techniques or involve unconventional functions.
Some tips for solving a troubling definite integral include breaking it down into smaller, more manageable integrals, using substitution or integration by parts, and utilizing special properties or symmetry of the integrand. It can also be helpful to review common integration techniques and practice solving similar problems.
Solving troubling definite integrals is important in many fields of science, such as physics, engineering, and economics, as it allows for the calculation of important quantities such as area, volume, and displacement. It also helps to understand the behavior of complex functions and can lead to new mathematical insights and discoveries.
