A water tank on mars
I have a cylindrical water tank of mars, where acc. due to gravity= 3.71
The pressure at the surface of the water is 110 kPa, and the depth of the water is 14.5 m
The pressure of the air outside the tank is 91 kPa
Find the net downward force on the tanks flat bottom of area 2.4 m^2, exerted by the water and air inside the tank and the air outside the tank
p= F/A
alright, I found the downward force to be 3.93x10^5 N
upward force to be 2.18x10^5
I thought the sum of these forces would give me the net forces but I must've been mistaken because the answer was wrong.
Answers and Replies
You've got the water pushing down, so you need to find the volume of water and figure out the mass(I guess you assume 1 mL= 1g) and mg(but not the normal g!)will be the downward force from the water alone
Also the air is pushing down on it, as is the outside air, both can be found using your equation
Don't forget if you use kPa and m^2 you get your answer in kN
I know the force from the outside air is 2.18x10^5 N, and the force of the water inside is 3.93x10^5 N, so if I find the force of the air inside the tank as well, the sum of them will give me what I'm looking for?
Related Threads on A water tank on mars
  • Last Post
  • Last Post
17K
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
