A4 subset of S4
  • Thread starter Juneu436
A question from artin 6.2:
Two tetrahedra can be inscribed into a cube C, each one using half the vertices. Relate this to
the inclusion A4 is a subset of S4.
I can only think that the tetrahedral group is isomorphic to A4, and the cube is isomorphic to S4. And since you can fit two tetrahedra in a cube, this would imply that A4 is a subset of S4.
Is this correct?
Thanks
Answers and Replies
If I can show that the group of rotational symmetries of a tetrahedron is A4 and the full group of symmetries of a tetrahedron is S4, then I can conclude that A4 is a subset of S4.
Does this approach satisfy the question?
I guess I don't understand what the question is even really asking. Isn't A4 defined to be a subset of S4?
Yeah, but I have to link A4 subset of S4 with the tetrahedra somehow.
Deveno
consider all the symmetries that map a cube to itself. these either map the two tetrahedra to themselves, or to each other.
identify A4 with the symmetries of the cube that map the 2 tetrahedra back into themselves.
for example, a 90 rotation along the x,y or z-axis (assuming the cube is aligned with these), swaps the 2 tetrahedra, and a 180 degree rotation preserves them. the "corner diagonal" rotations all preserve the 2 tetrahedra (they just rotate around a vertex from each of the 2 tetrahedra), while the "midpoint diagonal" rotations swap the tetrahedra.
one can view a symmetry of the cube as a permutation of it's 4 main diagonals. in this case, a 90 degree rotation is a 4-cycle (d1 d2 d3 d4) for example, a 120 degree rotation about a main diagonal is a 3-cycle (d2 d3 d4) for example, and an 180 degree rotation about a midpoint diagonal is a 2-cycle (d3 d4) for example.
a main diagonal corresponds to opposite vertex pairs (one from each tetrahedron). so a transposition of diagonals, swaps the tetrahedra. even permutations consist of pairs of transpositions, each of which swap the tetrahedra, so even permutations preserve the pair of tetrahedra.
Related Threads on A4 subset of S4
  • Last Post
13K
  • Last Post
15K
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
