Exploring the Energy Behind Gravity: Questions and Possibilities
In summary, there is a difference between force and energy, and the force of gravity only involves energy when it acts on an object over a distance. In the example of Earth and Moon, the energy from tides comes from the energy of their orbits, and the conservation of angular momentum law states that the Moon is constantly moving closer to the Earth. The energy that produces gravity comes from the potential energy of massive objects, and this is in line with Newton's theories of universal gravitation.
Vago Vent
I have been pondering on this for a while.
Gravity is a force, not energy. But where is the energy that produce gravity?
For an example.
If there only Earth and Moon existed and nothing else exists. (People and water are located underground inside the Earth or whatever the case that may be.) If the moon kept in perfect orbit where it does not move away or closer and creates the tides for water underground. People could produce energy from the tide, so where all the energy coming from? If gravity is not a form of energy, then what is the energy that produce gravity?
Does this break the "Law of Nature" philosophy in term of energy being not created?
Please and thank you for your time.
In this context think of energy as a force over a distance. The force of gravity only involves energy if it acts on an object over a distance. Book on a table -> its not traveling a distance so there is no energy involved. Book falling through the air -> The force of gravity is acting over a distance so the book is gaining energy.
As for your example, you shouldn't expect a 'perfect' orbit to produce energy from tides! The energy from tides comes from the energy of the Earth and moon's orbits. The distance between the earth/moon as well as the speeds of the Earth and moon are changing (slightly) as a result of us harnessing tides.
Can you explains more on that?
For gravity, when there is force, there have to be energy. Am I wrong?
A force does not require energy. Consider a spring that you can compress. The act of compressing it does require energy. Keeping it compressed with a force does not require energy. You can latch it in a compressed state and toss it into space, it will stay latched and compressed and no energy need be consumed.
For an example.
what you're describing is impossible. it's impossible for the moon to maintain its current distance from the earth, especially with all the energy the moon is using up by creating the tidal forces!
so where does all this energy from the moon exerting its forces on the Earth go? according to the conservation of angular momentum law, the moon is constantly moving closer to the Earth as it revolves around the earth.
again, it's not possible for the moon to maintain its current distance from the earth.
It moves further. Check your work.
There is usually an associated potential, so an object in gravitational field has potential energy.
Field itself also has energy. Gravitational field is not an exception, but this is getting into something a bit more complex.
Don't think of force as manifestation of energy, but rather as means of transfer of energy. If force is applied over distance, work is done, and energy is transferred from one body to another.
the energy that produces gravity is from the potential energy the planet Earth has, this energy is by nature come with all heavy mass objects, one evidence for that, that the gravity and the mass of the planet are direct proportional to each other, and otherwise you may think, this coincides with Newton's theories.
i recommend you to see chapter 13 of the serway/jewett physics book, google it, the chapter's title is "universal gravitation", you may find what you are looking for in it.
1. What is gravity?
Gravity is a fundamental force of nature that causes objects with mass to be attracted to one another. It is responsible for keeping the planets in orbit around the sun and for the motion of objects on Earth.
2. How does gravity work?
Gravity works by the curvature of space and time. Objects with mass create a dent in spacetime, and other objects are pulled towards this dent. The larger the mass, the stronger the gravitational pull.
3. Why is gravity important?
Gravity is essential for the formation and stability of the universe. Without gravity, planets, stars, and galaxies would not be able to form. It also plays a crucial role in everyday life, from keeping our feet on the ground to allowing us to breathe.
4. Can gravity be manipulated?
While we have not yet figured out how to manipulate gravity, there are theories and ongoing research that suggest it may be possible. Some scientists are exploring the idea of using gravity as a source of energy or creating artificial gravity for space travel.
5. What are the potential applications of understanding gravity?
Understanding gravity can lead to advancements in various fields, such as astrophysics, space exploration, and technology. It can also help us better understand the universe and its origins. Additionally, understanding gravity could potentially lead to new energy sources and technologies.
  • Other Physics Topics
  • Science Fiction and Fantasy Media
  • Classical Physics
