Questions about Repulsion Force: Is it Present & What Materials are Affected?
In summary, David Swenson of 3M Corporation shared a case study in which workers encountered an "invisible wall" caused by a large buildup of static charge on a plastic web in a factory. The phenomenon was observed in a cubical tent-like structure formed by the moving film, and was strong enough to prevent humans from passing through. This effect was found to be caused by ionized air released from the film as it was peeled from the spool, resulting in a large imbalance of charge and a repulsive force. The production manager was initially skeptical but later experienced the "wall" himself. Further investigation is needed to fully understand the mechanism behind this curious phenomenon.
kadombing
Hi all.
I have a few questions:
1. Is repulsive force present in any certain situation other than magnetic fields?
2. I read that a big enough electromagnet can attract or repel even a human being. Can the same effect attainable from a big enough magnet?
3. What materials are not being affected by this repulsive force?
4. And why a certain material is influenced and others are not influenced by it?
Thank you in advance, looking forward for your answers!
Hi there,
I will try to summarize:
1. electrical repulsion can also exist.
2. electromagnet are not different from magnet. anyway there magnetic field are identical.
3. no. A very strong magnetic field will affect any materials.
4. Depends on the atomic structure of the material.
Cheers
But can concrete, for example, be repelled or attracted?
Thank you for the reply.
Is there any way to classify them? Like which structure are being attracted and which are being repelled?
Look up "diamagnetism" and "paramagnetism".
Hi there,
With a strong engouhg magnetic field, even concrete would get some magnetic properties. For the attraction/repulsion, the question is kinda hard to answer. I can only say that it would react to the magnetic field.
There is a classification of matter according to magnetic fields. I am definately not an expert in the electromagnetism field, but I know about paramagnetic, diamagnetic, and ferromagnetic. You need to make a simple search on the Web to find out about the atomic magnetic properties of each class.
Cheers
It all depends on the magnetic susseptibility of the material. All materials like humans cats dogs and other animals as well as concrete are diamagnetic substances and so they repel any magnetic field applied on them
Thank you very much for the answers, going to do some searching on the web regarding paramagnetism, diamagnetism, and ferromagnetism.
Meanwhile, before finding this forum I found a curious article, what do you think of it?
Is it possible?
"Invisible Electrostatic Wall" at 3M adhesive tape plant
SESSION 7: SPECIAL SESSION, 17th Annual EOS/ESD Symposium
THURSDAY, SEPTEMBER 14, 1995, 8:00 am
SESSION 7: SPECIAL SESSION: ELECTROSTATIC CONSIDERATIONS IN INDUSTRY
MODERATOR: D. Swenson, 3M
7.7 CASE STUDY - LARGE PLASTIC WEB ELECTROSTATIC PROBLEMS, RESULTS AND
CURE, D. Swenson, 3M Company
Tremendous static charge generation on a plastic web causes unique
physical phenomena and special problems. Solution was simple and cost
effective.
Also see: article in the ESD Journal
David Swenson of 3M Corporation describes an anomaly where workers encountered a strange "invisible wall"
in the area under a fast-moving sheet of electrically charged polypropelene film in a factory. This "invisible
wall" was strong enough to prevent humans from passing through. A person near this "wall" was unable to
turn, and so had to walk backwards to retreat from it.
This occurred in late summer in South Carolina, in extremely high humidity. Polypropelene (PP) film on 50K
ft. rolls 20ft wide was being slit and transferred to multiple smaller spools. The film was taken off the main roll
at high speed, flowed upwards 20ft to overhead rollers, passed horizontally 20ft and then downwards to the
slitting device, where it was spooled onto shorter rolls. The whole operation formed a cubical shaped tent, with
two walls and a ceiling approximately 20ft square. The spools ran at 1000ft/min, or about 10MPH. The PP
film had been manufactured with dissimilar surface structure on opposing faces. Contact electrification can
occur even in similar materials if the surface textures or micro-structures are significantly different. The
generation of a large imbalance of electrical surface-charge during unspooling was therefor not unexpected, and
is a common problem in this industry. "Static cling" in the megavolt range!
On entering the factory floor and far from the equipment, Mr. Swenson's 200KV/ft handheld electrometer was
found to slam to full scale. When he attempted to walk through the corridor formed by the moving film, he
was stopped about half way through by an "invisible wall." He could lean all his weight forward but was unable
to pass. He observed a fly get pulled into the charged, moving plastic, and speculates that the e-fields might
have been strong enough to suck in birds!
The production manager did not believe Mr. Swenson's report of the strange phenomena. When they both
returned to the factory floor, they found that the "wall" was no longer there. But the production workers had
noticed the effect as occurring early in the morning when humidity was lower, so they agreed to try again
another day. The second attempt was successful, and early in the morning the field underneath the "tent" was
strong enough to raise even the short, curly hair of the production manager. The "invisible wall" effect had
returned. He commented that he "didn't know whether to fix it or sell tickets."
Problems: coulomb forces would be expected to *attract* a person into the "chamber" formed by
the PP film, and the attractive force should be fairly linear across distance. There should be no
"wall" in the center, a "wall" is repulsive and nonlinear.
If for some reason a person was repelled from the center of the chamber rather than being
attracted, there still should be no "wall," since the repulsion force should exist over a large distance;
it should act like a deep pillow which exerts more and more force as one moves deeper into it. It
should not behave like a "wall". This is how magnets and iron behave, and this is how e-fields and
conductive objects should also behave.
A thought: unspooling of film typically generates higher net charge on the long piece of film than on
the limited surface of the spool. However, since net charge is conserved, imbalances of charge
MUST be equal and opposite. The charge on the entire length of moving film MUST be equal in
magnitude to the charge on the spool, yet the charge on the film is very large and is continuously
increasing. The limited surface-charge on the spool indicates that opposite charge is being lost
through some unseen path, most probably as IONIZED AIR.
Charged air would arise in the cleft between film and spool as the film was peeled from the spool. I
wonder if film was peeled from the top of the spool, so that any ionized air would be launched into
the "tent-chamber" region? If it was peeled from the bottom of the spool, the charged air would end
up outside the "tent." Or, if a corona discharge arises in the cleft between film and spool, perhaps
the UV and e-fields of this corona can ionize the air on both sides of the exiting plastic film, and
spray the charged air everywhere.
So, if the charged "tent" of film is negative in the above situation, and if a large quantity of
positively charged air is being generated at the spool, then perhaps the "invisible wall" is caused by a
cloud of suspended air ions. Perhaps it is a pressure gradient created by ionized air trapped under
the tent by electrostatic attraction. Yet this effect would be expected to create a diffuse zone of
increasing force, not a "wall", but an "invisible pillow."
However, a volume of charged air is somewhat analogous to iron filings near a magnet. If a solid
sheet of iron filings is held in place by a magnet, then a literal "wall" is created, and this wall will
resist penetration by nonferrous objects. If in the above manufacturing plant a sheet of highly
charged air is for some reason being held in place by the fields created by the charged film, then a
transparent "wall" made of charged air would come into being. It might resist penetration by human
bodies.
My question is this: if the entire situation could be turned on its side, so the "invisible wall" became
an "invisible floor", could a person *stand* on it? Have we discovered the long-sought "Zero-G
waterbed?" :) - B.B.
Reference: Article about the "Wall" in ESD Journal (IT'S BACK! 8/2000)
Source: http://amasci.com/weird/unusual/e-wall.html
1. Is repulsion force present in all materials?
No, repulsion force is not present in all materials. It depends on the nature and properties of the material. Some materials, such as metals, have a strong repulsion force while others, like wood, have a weaker repulsion force.
2. What causes repulsion force?
Repulsion force is caused by the interaction between the electric charges of particles in a material. Like charges repel each other, creating a force that pushes the particles away from each other.
3. How does repulsion force affect the behavior of materials?
Repulsion force can affect the behavior of materials in various ways. It can determine the physical properties of a material, such as its shape and volume, and also play a role in the bonding between molecules.
4. Can repulsion force be manipulated or controlled?
Yes, repulsion force can be manipulated or controlled. This can be done by altering the charges of particles, changing the distance between particles, or introducing other forces that can counteract repulsion force.
5. How is repulsion force measured or quantified?
Repulsion force can be measured using various techniques, such as Coulomb's law or the use of specialized instruments like a force sensor. It is usually quantified in units of force, such as Newtons (N) or dynes (dyn).
  • Other Physics Topics
  • Electrical Engineering
  • Classical Physics
