About sorting method in Java
In summary, the issue with your code is that you are not merging the two sorted arrays correctly. You need to loop through both arrays in parallel, comparing and adding each element in the correct order.
lypaza
I wrote a class to sort Comparable elements in a list (ArrayList)
I have Student class that contains lastName, firstName, studentID, and tuitionFee as its instance variables.
At first I used mergeSort algorithm to write the Sorts class. It works when I add 1 student, still works with 2 students, but when I add 3 students, the IndexOutOfBoundsException occurs.
Here is my code:
Code:
import java.util.*;
public class Sorts
	public static void sort(ArrayList objects)
		mergeSort(objects, 0, (objects.size()-1));
	public static void mergeSort(ArrayList list, int start, int end)
		if (start < end)
			int mid = (int)Math.floor((start + end)/2);
			mergeSort(list, start, mid);
			mergeSort(list, mid+1, end);
			merge(list, start, mid, end);
	public static void merge(ArrayList list, int start, int mid, int end)
		int firstLength = mid - start + 1;
		int secondLength = end - mid;
		Comparable [] first = new Comparable[firstLength];
		Comparable [] second = new Comparable[secondLength];
		for (int i = 0; i < firstLength; i++)
			first[i] = (Comparable)list.get(i);
		for (int i = 0; i < secondLength; i++)
			second[i] = (Comparable)list.get(mid+1+i);
		list.clear();
		int i = 0;
		int j = 0;
		while ((i<firstLength) && (j<secondLength))
			if ( first[i].compareTo(second[j]) < 0)
				list.add(first[i]);
				i++;
			else
				list.add(second[j]);
				j++;
		while (i < firstLength)
			list.add(first[i]);
			i++;
		while (j < secondLength)
			j++;
I was staring at it without blinking but still don't get it :confused:
Can someone please help me to figure out what's wrong with my code?The problem you have is that you are not adding the elements from the first and second arrays back into the list in the correct order. When you merge two sorted arrays, you should compare the elements at the same index in both arrays and add the one that is smaller to the list. This means that you need to loop through both arrays in parallel and add the elements one by one. Your code is adding all of the elements from the first array before looping through the second array. Instead, you should be looping through both arrays in parallel, comparing and adding each element. You can do this with a while loop like this: while (i < firstLength && j < secondLength) { if (first.compareTo(second[j]) < 0) { list.add(first); i++; } else { list.add(second[j]); j++; }}After the while loop, you should add any remaining elements from either the first or second array. while (i < firstLength) { list.add(first); i++;}while (j < secondLength) { list.add(second[j]); j++;}
Hi there,
It seems like you are trying to use a mergeSort algorithm to sort a list of Student objects in your Java program. However, you are running into an IndexOutOfBoundsException when you try to sort a list with three or more students.
First of all, great job on implementing a sorting algorithm in Java! It looks like you have a good understanding of the mergeSort algorithm and how it works. However, there seems to be an issue in your merge method.
In your merge method, you are using a for loop to add elements from the first and second arrays to your list. However, you are using the variable "mid" to access elements from the second array, which may be causing the IndexOutOfBoundsException. Remember, the variable "mid" represents the middle index of the entire list, not just the second array.
To fix this issue, you can change the for loop to start at "mid+1" instead of "0". This will ensure that you are only accessing elements from the second array, and not trying to access elements beyond the size of the array.
I hope this helps and good luck with your sorting algorithm! Keep up the good work!
1. What is sorting method in Java?
Sorting method in Java is a process of arranging data in a specific order or sequence. It is used to organize data in a more efficient and accessible way, making it easier to search and retrieve information.
2. What are the different types of sorting methods in Java?
There are several types of sorting methods in Java, including bubble sort, selection sort, insertion sort, merge sort, quick sort, and heap sort. Each method has its unique approach to sorting and has different time and space complexities.
3. How does the sorting method work in Java?
The sorting method in Java works by comparing elements in the data set and rearranging them in a specific order. The comparison is usually based on specific criteria, such as numerical value or alphabetical order. The sorting process continues until all elements are in the desired order.
4. What is the time complexity of sorting method in Java?
The time complexity of a sorting method in Java refers to the amount of time it takes to execute the sorting algorithm. It is usually measured in Big O notation, and the best sorting methods have a time complexity of O(nlogn), which means they can sort a data set in a relatively short amount of time.
5. Can I implement my own sorting method in Java?
Yes, you can implement your own sorting method in Java by creating a custom algorithm that sorts data according to your specific needs. However, it is essential to consider the time and space complexity of your method to ensure efficient sorting.
