Square Root Rules: x^(1/2), abs(x), F(x), & More!
In summary, there are various rules for square roots and other roots, but they have restrictions on the values of x and y. However, there is no rule for simplifying the square root of a sum or difference. The closest approximation would be the binomial formula, which involves infinite sums.
Emmanuel_Euler
142
hi guys
i know all square root and any root(cubic...) rules
sqrt(x)=x^(1/2)
sqrt(x^2)=abs(x)
sqrt(xy)=sqrt(x)*sqrt(y)
sqrt(x/y)=sqrt(x)/sqrt(y)
sqrt(-x)=isqrt(x)
f'(x)=1/2sqrt(x)
F(x)=2/3*(x^3/2)
my question is:
is there any rules for this sqrt(x+y)
or sqrd(x-y)??
any help please??
No, there is no way to simplify a square root (or other root) of a sum or difference.
It's simply a case of "multiplication and addition do not play well together!"
Likes Emmanuel_Euler
Yes of course.
Yesterday i was searching about this(sqrt(x+y)),i found nothing.
you are right there is no rule for this sqrt(x+y)
thanks for help friend.
Emmanuel_Euler said:
hi guys
sqrt(x)=x^(1/2)
sqrt(x^2)=abs(x)
You should be aware that there are restrictions on x and y; namely, both must be nonnegative. I.e., x ≥ 0 and y ≥ 0. Without these restrictions you get nonsense like ##1 = \sqrt{1} = \sqrt{-1 * -1} = \sqrt{-1} * \sqrt{-1} = i * i = -1##
There are restrictions here, as well, with x ≥ 0 and y > 0.
sqrt(-x)=isqrt(x)
Not true. For example, if x = -4, then ##\sqrt{-(-4)} = \sqrt{4} = 2##. ##i\sqrt{-4} = i * (2i) = 2i^2 = -2##.
Here you seem to be tacitly assuming that -x will be negative, which is not true in general.
f'(x)=1/2sqrt(x)
F(x)=2/3*(x^3/2)
my question is:
or sqrd(x-y)??
any help please??
Friend:i know all the rules you wrote.
i was too busy to write them all(in my question).
But if you really want to help me,find a rule for this sqrt(x+y).
Forgive me!, i was busy and hurry.
There is no such rule.
Period.
You are right.
That helps.
thank you for help,i will read it later!
What is the square root of a number?
The square root of a number is a value that, when multiplied by itself, gives the original number. For example, the square root of 25 is 5 because 5 x 5 = 25.
How do you find the square root of a number?
The square root of a number can be found using a calculator or by using the square root symbol (√) followed by the number. For example, √25 = 5.
What are some common square root rules?
Some common square root rules include the product rule (√(ab) = √a x √b), the quotient rule (√(a/b) = √a / √b), and the power rule (√(a^2) = |a|).
What is the difference between x^(1/2) and √x?
Both x^(1/2) and √x represent the square root of x. However, x^(1/2) is a mathematical notation, while √x is the square root symbol used in calculators and textbooks.
How are square roots used in real life?
Square roots are used in many fields such as engineering, physics, and finance. They are used to calculate distances, areas, and volumes, as well as in formulas for mortgage payments and compound interest.
  • Calculus
  • Calculus
  • Calculus
