I About this conservation law...
  • Thread starter space-time
In my quest to learn how to solve the geodesic equation, I came across this law which apparently holds true for all metrics (according to what I read):
gab(dxa/dτ)(dxb/dτ) = -1
Well, I tested this formula out with Minkowski space (- + + + signature):
If I understand correctly, then in Minkowsi space:
(dx0/dτ) = (dt/dτ) = Φ where Φ is the relativity factor 1/sqrt(1 - v2/c2)
(dx1/dτ) = (dx/dτ) = vxΦ where vx is the x-component of velocity
(dx2/dτ) = (dy/dτ) = vyΦ
(dx3/dτ) = (dz/dτ) = vzΦ
Therefore, the expression gab(dxa/dτ)(dxb/dτ) evaluates to:
2 + ( vx)2Φ2 + ( vy)2Φ2 + ( vz)2Φ2
This turns into:
2 + v2Φ2
which can be factored into:
(-1 + v22
The above expression does not always = -1.
In fact the above expression is:
(-1 + v2) / (1 - v2/c2)
This expression would only = -1 if either v = 0 or c = 1 (and the latter case is a matter of convention, I usually keep c = 3 * 10^8 m/s).
Having said this, where am I going wrong in my understanding (or my math in case I made any simple mistakes)? Apparently, this conservation law can be taken advantage of in order to solve some geodesic equations, but the fact that this does not = -1 for all v is throwing me off when it comes to the law.
I have one hypothesis as to the answer of my own question:
Geodesics describe the world lines of objects that are in a state of "free fall". They have no forces acting on them aside from gravity (which is not a force, but spacetime curvature in the sense of relativity). Is it possible then that this law expects v = 0 to be the case?
Orodruin
Staff Emeritus
Insights Author
2018 Award
15,760
5,759
You are mixing up expressions from texts using c=1 and texts not using such units. As a result, your results are only valid in units where c=1 and there is nothing strange about that.
In general units where c is not equal to one the 4-velocity is normalised such that ##V^2 = -c^2## and the metric has factors of c in it that you missed.
Thank you for this post. I have just one more question. You said that I am missing factors of c in the case where c is not 1. Where am I missing those factors of c?
The form of the line element that I used when evaluating the metric tensor contracted over the derivatives is:
ds2 = -c2dt2 + dx2 + dy2 + dz2
The c term is there. Where then am I missing factors of c? Thank you for your assistance.
Nugatory
Mentor
12,191
4,657
What value are you using for ##g_{00}## here?
If an object is in free fall (no proper acceleration, no force acting on it) then there always exists a local inertial frame in which the ##v=0## - but once you restore your lost ##c## you'll find that the invariant works even for non-zero ##v##.
I'm using -1 for g00.
Also, what missing c?
I'm using
Nugatory
Mentor
12,191
4,657
You may be using -1 for ##g_{00}##, but the line element you just wrote down says that it is ##-c^2## not ##-1##.
Ibix
Insights Author
5,129
3,423
When ##c## has been left out, you can put it back in by dimensional analysis. All terms in the expression ##g_{ab}U^aU^b=1## must have the same units, but note that ##dt/d\tau## has different units to ##dx/d\tau## if ##c\neq 1##, and the terms on the left hand side largely have dimensions of velocity squared.
Thanks guys I got it. When I did the calculation again using -c2 as g00 , I got -c2 as my answer to gab(dxa/dτ)(dxb/dτ)
If c is taken to be 1, then this would correspond with the whole gab(dxa/dτ)(dxb/dτ) = -1 rule.
In that case, I guess the general rule for any units (not just c = 1 units) would be:
gab(dxa/dτ)(dxb/dτ) = -c2
for the ( - + + +) signature. Is this correct?
Ibix
Insights Author
5,129
3,423
Looks right. I must say I've taken to dropping the factors of ##c## and just working in units like light seconds and seconds. Translating back to SI units is trivial.
vanhees71
Insights Author
4,860
It's simply ##x^0=c t##. Then ##g_{\mu \nu}=\mathrm{diag}(-1,1,1,1)##. Just set ##c=1##, which are the natural units, and you don't stumble over these annoying factors of ##c## anymore ;-))). SCNR.
Want to reply to this thread?
"About this conservation law..." You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
