- 16
Hi everybody
What is Time?
I gave a thought to this question and came to the conclusion that the accepted definition for Time is incorrect.
The definition of time which we use is:
“Non spatial continuum in which the events occur.”
My definition is:
“Relation between two events in the continuum of events”
Time is relevant and limited to the events.
In philosophical discussions (science uses philosophy) I always introduce the idea about the hierarchy in the mind concepts.
Every mind concept appears in certain hierarchical order and by changing the hierarchy we end up with fallacy.
In this particular argument the time is placed before the events.
The definition of time IMPLIES that the events appear IN time, but it is actually the other way round - time is created as concept from the relation between two or more events.
My arguments:
1) If there are no events in the Universe there will not be time.
Some people will argue that there will be time but we will not be able to measure it.
That would be fallacy.
We measure time with time which is actually event with event (circle around the sun with spins around the Earth axis)
The logical conclusion is that we cannot apply time to a motionless universe.
How do we measure time? - with reoccurring event.
What is to MEASURE time? - it is to relate one event to another event.
I think that this is quite clear.
2) We need two or more events in order to have time as existing concept.
One event is insufficient for time creation.
To have “motion” we need universe with minimum two objects.
To have “time” we need universe with minimum two events.
If there is universe with one only object, that object can not exhibit motion and cannot exist in time.
It can only exist as motionless in space.
The definition of time does not apply to such Universe.
If the Universe is created from two objects, which are moving away from each other, according to the definition of time we should have time, but how can we explain and how can we measure time in such universe?
In this case we can only claim that an event occurs in space, but not in time.
3) When you argue the above, do not refer to the already built mind concept of time.
- Have in mind, that you already have the time concept from at least two events in your life.
Note that your thinking is an event too.
- Do not use “speed” for proving “time”.
Speed is related to motion.
If we have only two moving away from each other objects, speed has no use for time.
- Relation between to events is for example “the number of Earth spins in one circle around the sun”.
- Every time-measuring tool is “event”
- All events appear in space except the thought (the thinking).
Well, this is my idea about “time”.
Most probably I missed something, but that is why I put it on discussion :-)
I am interested whether the above interpretation can affect the physics and if yes, to what extent.
What is Time?
My definition is:
My arguments:
