About weak potential (solid state)
In summary, the long-range nature of electron-electron and electron-ion interactions makes it difficult to accurately calculate energy gaps in three-dimensional systems using perturbative methods, and Fourier transforms may be necessary to accurately calculate these energy gaps at lower wave vector magnitudes.
armandowww
78
In solid state physics, a proof of bearing energy gaps in one-dimesional dispersion relations is given by a quantum-mechanical perturbative approach applied to the level belonging to two bands at once, that is twice degenerate. For example for k=pi/a there's one of these levels between n=0 band and n=-1 band.
The method is able to make visible the reason for which lower level is going lower again and upper, upper itself.
I read somewhere that passing to tridimensional problem is not clever, not for a computational subject, but for the intrinsic long range property of electron-electron and electron-ion interactions. They go like 1/x.
Now, here's my question: Should I deal with Fourier trasforms to reach some kind of a comprehension of this inability? They should go like 1/k^2, too slow to compensate in k-space (i.e. N-space) the fast growth of sites number: the volume of infinitesimal spherical shell N^2dN. If so, where's the cause?
Thanks for your paid attention.
The inability to pass to a three-dimensional problem is due to the fact that the long-range nature of electron-electron and electron-ion interactions make it difficult to accurately calculate the energy gaps in a three-dimensional system. Even with perturbative methods, the energy gaps cannot be accurately calculated for three-dimensional systems due to the fact that the interactions become less important as the distance between particles increases. The interactions also become less important as the wave vector magnitude increases, meaning that the energy gaps cannot accurately be calculated using perturbative methods for higher wave vector magnitudes. Therefore, when dealing with the energy gaps in three-dimensional systems, Fourier transforms may be used to effectively calculate the energy gaps at lower wave vector magnitudes.
I would like to provide a response to the content you have shared about the weak potential in solid state physics. It seems that you are discussing a specific method used to study the energy gaps in one-dimensional dispersion relations, where the levels belonging to two bands are considered to be twice degenerate. This method is able to explain why the lower level goes lower and the upper level goes higher.
You also mention that this method may not be suitable for studying three-dimensional problems due to the long-range nature of interactions between electrons and ions. These interactions follow a 1/x relationship, which is much slower than the 1/k^2 relationship observed in Fourier transforms. This could potentially lead to difficulties in understanding the underlying cause.
In order to fully comprehend this inability, it may be necessary to use Fourier transforms to gain a better understanding of the situation. However, it is important to note that Fourier transforms alone may not be sufficient to explain the cause of this limitation. Further research and analysis may be required to fully understand the underlying factors at play.
Thank you for bringing this topic to my attention and I appreciate your interest in this area of study. it is important to continually question and explore the limitations of our current methods and strive to find new and improved ways of understanding the natural world.
What is weak potential in solid state physics?
Weak potential in solid state physics refers to a potential energy that is relatively low compared to other types of potentials, such as strong or electromagnetic potentials. It is often used to describe interactions between particles in a solid material.
How is weak potential related to crystal structures?
Weak potential is closely related to crystal structures because it is responsible for the stability and properties of crystals. The weak potential is responsible for the bonding between atoms in a crystal lattice, determining the overall structure and behavior of the material.
What are some examples of materials with weak potentials?
Materials with weak potentials include metals, insulators, and semiconductors. For example, copper has a weak potential, which makes it a good conductor of electricity, while diamond has a strong potential, which makes it a good insulator.
How does the strength of a weak potential affect the properties of a material?
The strength of a weak potential can significantly impact the properties of a material. For instance, materials with a weaker potential may have lower melting and boiling points, be more malleable, and have lower densities compared to materials with a stronger potential.
Can weak potentials be manipulated or controlled?
Yes, weak potentials can be manipulated or controlled by external factors such as temperature, pressure, and electric or magnetic fields. This manipulation can alter the properties of a material, making it useful for various applications in technology and industry.
  • Atomic and Condensed Matter
