Homework Help: Absolute Extrema: 2 variables
  1. Mar 9, 2013 #1
    Find the absolute extrema of the function on the set D.
    f(x,y)= x^2 + 4y^2 + 3x -1
    D= {(x,y) l x^2 + y^2 ≤ 4}
    2. Relevant equations
    3. The attempt at a solution
    The only thing I've done so far was find the critical point. I found f-sub x = 2x+3 and f-suby= 8y giving me a critical point of (-3/2,0), correct?
    Using that critical point, I found f(-3/2,0) = -1
    After that, I don't know how to proceed. I know -2 ≤ x ≤ 2 and -2 ≤ y ≤ 2 but how do I find the other critical numbers with that info? I'm unsure because the closed boundary graph is a circle and not a square, box, or triangular region.
  3. Mar 10, 2013 #2
    ehild
    f(-3/2) is not equal to -1.
    The absolute extreme can be on the perimeter. Find the critical point with the condition that x2+y2=4.
    ehild
  4. Mar 10, 2013 #3
    Ah, you're right, thank you. For that, I got -13/4.
    So set y=√(4-x^2) ? and find f(x,√(4-x^2)). Then find values of x and use the result to find y. Then find critical numbers? Because that's what I did but it didn't seem right.
  5. Mar 10, 2013 #4
    Ray Vickson
    You have found the global minimum of f, subject to g = x^2 + y^2 <= 4. (although your f is wrong while your (x,y) is correct). However, an extremum can also be a maximum, and you have not yet found that.
  6. Mar 10, 2013 #5
    ehild
    That is right.
    Show your work.
    ehild
  7. Mar 10, 2013 #6
    Thanks, guys! I got it now. I forgot to take the derivative of f(x,√(4-x^2)).
    Instead of finding the derivative, I found x and y of f(x,√(4-x^2)) and plugged it into the original function which was wrong.
Have something to add?
Draft saved Draft deleted
