Is it Possible for an Absolute Value Equation to Equal a Negative Number?
In summary, the absolute value of any quantity, whether real or complex, always results in a non-negative real number. This is because the absolute value function represents the distance from one thing to another, and distance is always positive. This means that there are no real or complex numbers that can satisfy an absolute value equation equal to a negative number. The presence of a minus sign in front of the absolute value function may cancel out, but it ultimately depends on the value of the quantity inside the function.
mathdad
1,283
Precalculus by David Cohen 3rd Edition
Chapter 1, Section 1.2.
Question 68, page 11.
Before typing the textbook question, I must say that I have not been able to find a satisfactory answer to absolute value equations that equal a negative number.
Question:
Explain why there are no real numbers that satisfy the equation | x^2 + 4x | = - 12.
Aside from the question above, can we say the answer is a complex number?
Mathematics news on Phys.org
Question:
Actually, there won't be any complex solutions, either. That's because, if $z$ is a complex number, its magnitude $|z|$ is defined to be the real number representing its distance from the origin. So, if $z=a+ib$, then $|z|^2=z \cdot \bar{z} = (a+ib)(a-ib)=a^2+b^2,$ which is real and non-negative. Therefore its square root, $|z|,$ will be also.
Conclusion: the result of taking the magnitude (absolute value) of any quantity, real or complex, is always a real number. Moreover, that real number is always non-negative. There are no exceptions to this rule, either in the real numbers or in the complex numbers.
Think of it this way: you want to measure the distance from one thing to another thing. So you get out your tape measure and measure the distance. Can you ever get a negative number as the result? No? Well, you can always think of any absolute value/magnitude as the distance from one thing to another, even if one of them is zero: $|x|=|x-0|=$ distance from $x$ to $0$. You can also look at the definition of the absolute value function:
$$|x|=\begin{cases}\!\!\!\!&\phantom{-}x,\quad x\ge 0 \\ \!\!\!\!&-x,\quad x<0 \end{cases}.$$
The result in either case is always non-negative.
What if there is a minus sign in front of the absolute value?
Let a be any real number.
- | a | = - a, right?
- | - a | = - (a) = - a, right?
Almost. You can think of the minus sign as canceling: $|a|=a$. But now, whether there's a solution or not depends greatly on $a$. If $a>0$, there is one solution: $a$. The reason why $-a$ is not a solution is that you'd have to plug it in on both sides of the equation, including the RHS. But then you have a magnitude sign equal to a negative number, which can't happen. The same goes for if $a=0$, but of course there, you already know what $a$ is! If $a<0$, there is again no solution, for the reasons we've stated above.
Interesting ideas.
What is an absolute value equation?
An absolute value equation is a type of algebraic equation that includes an absolute value expression. The absolute value of a number is its distance from 0 on a number line. An absolute value equation has the form |x| = a, where a is a positive number.
How do you solve an absolute value equation?
To solve an absolute value equation, you must isolate the absolute value expression on one side of the equation and the constant on the other side. Then, you can solve for both the positive and negative values of x by setting up two separate equations. Finally, check your solutions by plugging them back into the original equation.
What are the possible number of solutions for an absolute value equation?
An absolute value equation can have either one solution, two solutions, or no solution. It depends on the value of the constant in the equation.
Can an absolute value equation have an infinite number of solutions?
Yes, an absolute value equation can have an infinite number of solutions if the absolute value expression is equal to 0. This is because any number multiplied by 0 is equal to 0, so all real numbers would satisfy the equation.
How are absolute value equations used in real life?
Absolute value equations are used in various real-life situations, such as calculating distance, finding the magnitude of a force or velocity, and determining the range of values that satisfy a given condition. They are also used in physics, engineering, and other scientific fields to model and solve problems involving absolute values.
  • General Math
  • General Math
  • General Math
25K
  • General Math
