How do I graph an absolute value inequality in 2 variables?
In summary, graphing an Absolute value can be done by breaking it into regions and finding a simple linear function for each region. The algorithm to follow includes determining the zeros, converting the absolute value terms, simplifying the expression, and iterating with the next region. For graphing inequalities in two variables, you can use www.webgraphing.com and represent |x| as abs(x).
Triggy
I need some help graphing an Absolute value. I know what it look like from a graphing calculator but I don't understand how to get to the answer.
http://media.twango.com/m1/original/0042/5fda15431b96400eb32e66afa3627624.jpg
Thanks
Mathematics news on Phys.org
With one like that the best method is to break it into regions. Just get a simple linear function for each of the following three regions and you're done.
1. x < -1
2. -1 <= x <= 1
3. x > 1
Following uart, adhere to this algorithm when doing abs.val problems:
1. Determine the zeros of each absolute value term, and mark these off on a number line.
2.Within each region, every absolute value term is now easily converted into a non-absolute-alue term
3. Simplify the expresion you have gotten for each interval, and draw that portion of the graph.
4. Iterate with the next region.
graphing inequalities in 2 variables
Triggy,
You can plot your inequality on www.webgraphing.com. There, you will get both the plot of the curve and the region where the inequality holds. Just use the link to "Inequality Graphing in Two Variables." To represent |x|, use the notation abs(x).
What is the definition of absolute value?
Absolute value is the distance of a number from zero on a number line, regardless of its sign. It is always represented as a positive value.
How do you graph an absolute value function?
To graph an absolute value function, you plot the points by substituting different x-values into the function and then connecting them with a straight line. The resulting graph will have a V-shape.
What is the difference between a positive and negative absolute value?
A positive absolute value will always result in a positive value, while a negative absolute value will result in a negative value. For example, the absolute value of -5 is 5, but the absolute value of 5 is also 5.
Can an absolute value function have more than one solution?
Yes, an absolute value function can have two solutions if the absolute value is set equal to a positive number. For example, the equation |x| = 5 has two solutions, x=5 and x=-5.
How do absolute value graphs show symmetry?
Absolute value graphs have symmetry about the y-axis, which means that the left and right sides of the graph are mirror images of each other. This is because absolute value is always positive, so the graph is reflected on the y-axis.
  • General Math
  • General Math
  • General Math
  • General Math
