Homework Help: Absorption length
  1. Jan 3, 2016 #1
    Aluminium (Ar = 26.98, ρ = 2700 kg/m3) has cross-section of thermal neutron absorption 0.23 barn. What is the absorption length of thermal neutrons in the aluminium? What value decreases neutron intensity in 0.6 mm, 8 mm and 80 mm aluminium?
    2. Relevant equations
    Beer-Lambert Law
    I'm not sure what x and lambda are in this equation.
    3. The attempt at a solution
    I'm not sure how to calculate the absorption length from the information provided.
    Absorption length
    [PLAIN]http://gisaxs.com/images/math/c/5/0/c50b9e82e318d4c163e4b1b060f7daf5.png, [Broken] the distance over which the intensity falls to 1/e.
  3. Jan 4, 2016 #2
    BvU
    2017 Award
    is strange when you then state
    . Or are you worried about the relation between ##P## and intensity ?
    Is it really that hard to imagine what ##x## could be ?
    Did you Google some examples ?
  4. Jan 5, 2016 #3
    The intensity falls to 1/e = absorption length. But what is the original intensity?
  5. Jan 5, 2016 #4
    BvU
    2017 Award
    Why not use 1 for the original intensity ? Or ##I_0## and gamble that ##P = {I\over I_0} ## :smile: ? At least then you can move on !
  6. Jan 5, 2016 #5
    ##P = {I\over I_0} ## = 1
    1/e = .367
    1-.367879 = 0.633
    The intensity has fallen, I'd assume x is the distance the thermal neutron has traveled through the atom, maybe. not sure about lambda though.
  7. Jan 5, 2016 #6
    BvU
    2017 Award
    We're not making much headway like this. Can you imagine an aluminum plate with a certain thickness, for example 0.6 mm, at which a beam of thermal neutrons is directed. The plate is a void with an awful lot of aluminum atoms. For a neutron in the beam this looks like a volume with a certain density of targets with an area of 0.23 barn per atom, the neutron cross section.
    Thicker plate, more targets. Your ##\lambda## has something to do with the density and the area of these targets.
    You have a textbook or lecture notes to introduce you to the matter at hand ? This exercise doesn't come out of the blue, I should think?
  8. Jan 5, 2016 #7
    You'd be surprised...
    λ = density * area of sphere ? (Assuming nucleus has a sphere shape)
    = density * 4*pi*radius of atomic nucleus
  9. Jan 5, 2016 #8
    If I take the value of kinetic energy from that link you posted. 0.025 eV I can calculated the scattering cross section. From there I can calculate the absorption cross section.
  10. Jan 5, 2016 #9
    BvU
    2017 Award
    My impression is the 0.23 nb is the absorption cross section. The exercise is a lot simpler than you now make it look.
  11. Jan 5, 2016 #10
    Yes, that makes sense. 0.23 is the absorption cross section. I have absolutely nothing in my lecture slides relating to neutron cross section or neutron absorption. No mathematical equation in which I can understand what happens. Is λ the mean free path?
  12. Jan 5, 2016 #11
    Σ=attenuation coefficient cm-1
    N= Atom density
    σ = cross section
    Σ=Nσ
    Σ=621 cm-1
    λ=1/Σ= 1/621=0.00161
  13. Jan 5, 2016 #12
    BvU
    2017 Award
    What do you get for N ? And how come your units end up as cm-1 ?
  14. Jan 5, 2016 #13
    Sorry, N = density = ρ = 2700 kg/m3
    I can see this isn't correct now though through dimensional analysis. density * cross section = kg/m3 * m2 ≠ cm-1
  15. Jan 5, 2016 #14
    BvU
    2017 Award
    You want the number of Al atoms per volume, not the density in kilograms per volume !
  16. Jan 6, 2016 #15
    oh ok, so number density = number of objects / volume = 100.74
    100.74*.23 = 23.017 cm-1
    λ=1/Σ= 1/23.017=0.043446
    0.367 = e^-x/lambda
    -1.00239 = -x/0.043446 =
    x= -0.04355
    This answer is still incorrect. The solution is 0.639 m according to my textbook but I don't see how I can get that.
  17. Jan 6, 2016 #16
    BvU
    2017 Award
    Do you seriously believe there are 100 Al atoms in a 1 m3 block of Aluminum ? Or do you work in some other system of units ?
Have something to add?
Draft saved Draft deleted
Loading...
