Abstract algebra 2 questions
In summary: The implication in the original question is that if a group is cyclic, then it has a subgroup isomorphic to Z_p X Z_p for every prime p. The implication in the new statement is that if a group has a subgroup isomorphic to Z_p X Z_p for some prime p, then it is cyclic.
kewljcs
1. If G is a finite group that does not contain a subgroup isomorphic to Z_p X Z_p for any prime p. prove that G is cyclic
im stumped. i don't understand the 'does not contain a subgroup isomorphoc to Z_p X Z_p part.
ive tried using cauchy's theorem for abelian group: if G is a finite abelian group, and let p be a prime that divides the order of G. then g has an element of order p.
so, Z_p is a finite cyclic gruop, but Z_p X Z_p is not because p, p are not relatively prime.
what else.. :/
2 question: Let G be a group of odd order. prove that the mapping x --> x^2 from G to itself is one to one.
i know that the smallest group of odd order is {I, a, a^-1}. i don't understand the mapping, basically.
For the first one you need to think about the classification theorem for finite abelian groups. Basically (Zp)^n for n>2 contains Zp x Zp as a subgroup. For the second one, if your map isn't one to one then there are two elements such that x^2=y^2 and x is not equal to y. Can you use that to show there is an element of order 2? What would that imply?
i think i got the second one. since the mapping is from G to itself, the order is the same, so we're showing that the kernel of this mapping is 0. right?
so i said that suppose x belongs to the kernel of the mapping, we want to show that x must be the identity, e.
this implies that the mapping is injective. hence, 1 to 1 since we are mapping from G to G.
then, x^2 =e. order of the element divides the order of the group, but |x| =2 => does not divide the order of the grup, which is odd.
does that work?
im still lost about the first one. we didnt learn about that classification theorem which u mentioned.
Actually, I may have spoken too quickly. Are these abelian groups? Somehow I was thinking they are. But your statement really didn't say that explicitly. If they are not I'd better give it some more thought.
u mean for the 1st question?
also, is my solution to the 2nd question correct?
I'm asking if G is abelian for both questions. Your solution for the second one is correct if the mapping x->x^2 is a homomorphism, which it is if G is abelian.
well, if G is cyclic in the end, then we know that it is abelian.
but I am not sure if we can use what we're trying to prove to do that :/
You are right on that. If they don't give you that G is abelian, you can't use a fact about the conclusion to prove it. These are both easy questions if you assume G is abelian. If you don't, they start to seem much harder. Got to admit, I'm having some doubts as to whether they are even true. They both smell like abelian group problems. BTW why did you say "cauchy's theorem for abelian groups". You know it's true for any group, right? That may have been what set off my abelian assumptions.
A counterexample for the first one is S3.
Ok, THANKS Hurkyl! I was really expending all my brain cells on trying to find a counterexample of the second one, and realizing I didn't know that many odd order nonabelian groups. That helps a lot.
Oh bleh, neither do I. I spent a few moments trying to make a matrix group, but all the ones I could come up with had even order or were Abelian.
(cheats by looking at a list of all small groups)
Apparently the smallest one is the "Frobenius group of order 21". I don't know what a Frobenius group is, but it's presented by
<a,b | a^3 = b^7 = 1, ba = ab^2>​
Nice. Is x->x^2 injective? Just kidding. I really think these questions are about abelian groups anyway. Thanks again for making that obvious.
so, are you all saying that the first question is wrong?
im still lost now. :/
to paraphrase question 1 :
Prove that a finite Abelian group fails to be cyclic if and only if it has a subgroup
isomorphic to Zp × Zp , for some prime p .
That's not a paraphrase, but a new statement. You changed the implication to a bi-implication ("only if" to "if and only if") and you added the assumption that G is abelian. For anyone to help you, you really need to take a look at your question and write it down as it was given. As Dick and Hurkyl have deduced your original question 1 was wrong, but if you add the assumption that G is abelian then Dick has already given you some great advice.
If you haven't covered the classification of finitely generated abelian groups yet try the following. Let us prove the contrapositive instead:
If G is not cyclic, then it has a subgroup isomorphic to [itex]\mathbb{Z}_p \times \mathbb{Z}_p[/itex] for some prime p.
Assume G is not cyclic. Let a be an element of G of maximal order. Since G is not cyclic you have [itex]\langle a \rangle \not= G[/itex]. Let b be an element in G, but not in the cyclic subgroup generated by a. Let m be the order of a and n be the order of b. Then what is the order of ab and what can we deduce from that? (Remember m was the maximal order of a cyclic subgroup) Can you use this to construct a subgroup of G isomorphic to [itex]\mathbb{Z}_p \times \mathbb{Z}_p[/itex]?
1. What is Abstract Algebra 2?
Abstract Algebra 2 is a branch of mathematics that deals with the study of algebraic structures, such as groups, rings, and fields. It builds upon the concepts learned in Abstract Algebra 1 and explores more advanced topics.
2. What are the important concepts in Abstract Algebra 2?
Some of the important concepts in Abstract Algebra 2 include group theory, ring theory, field theory, and Galois theory. These concepts are used to study the properties and relationships between algebraic structures.
3. How is Abstract Algebra 2 different from Abstract Algebra 1?
Abstract Algebra 2 builds upon the concepts learned in Abstract Algebra 1 and explores more advanced topics such as Galois theory, which is not covered in Abstract Algebra 1. It also introduces new algebraic structures, such as fields and vector spaces.
4. What are the applications of Abstract Algebra 2?
Abstract Algebra 2 has many applications in mathematics, computer science, and physics. It is used to study symmetry and patterns in nature, encryption algorithms in computer science, and symmetry principles in quantum mechanics.
5. What are some resources for learning Abstract Algebra 2?
Some recommended resources for learning Abstract Algebra 2 include textbooks such as "Abstract Algebra" by David S. Dummit and Richard M. Foote, online courses on platforms like Coursera and edX, and video lectures on YouTube. It is also beneficial to practice solving problems and proofs from textbooks or online resources.
  • Math POTW for University Students
  • Linear and Abstract Algebra
