• Support PF! Buy your school textbooks, materials and every day products Here!
Abstract Class return
  • Thread starter Robben
How can I return a new class object in an abstract class?
None
Suppose I have an abstract class named Animal (there are many other animal types that are made as classes). In this abstract class it has two methods, reproduction(Animal otherAnimal) and reproducing(Animal otherAnimal). Reproduction determines if the animal can reproduce with another instance of an animal. Reproducing should return a new Animal of the same type if reproduction is possible, but I do not know how to do this because the class is abstract.
Java:
public abstract class Animal{
    public abstract boolean reproduction(Animal otherAnimal);
    public Animal reproducing(Animal otherAnimal) {
        if (reproduction(otherAnimal) == true) {
            return ... //how can I return a new Animal of the same type?
        else {
            return null;
Answers and Replies
Borg
2,312
You could modify the reproduction(otherAnimal) method to return the type of Animal instead of a boolean. Otherwise your reproducing() method would have to know about all of the different variations that could be produced by all animals.
For example, if a horse has its reproduction method called by another horse, you could return a horse. If it's called by a donkey then it would return a mule. If it is called by some other animal like a tiger, then return null. The reproduction method for a horse would just have to know about donkeys and other horses. Once you implement it, you'll see that the reproducing method isn't really necessary - just the reproduction() method.
But I need these two methods. The reproduction method should only return whether or not two instances can reproduce and nothing more.
Borg
2,312
Is reproducing() required by your instructor? What if you had reproduction() return null when a viable animal wasn't possible?
Yup.
The details of reproduction with other animals will be written in different classes which will be a subclass of Animal so reproduction with two different animals that aren't possible should not occur.
Borg
2,312
If you put reproducing() in the abstract Animal class, it's going to have to be able to return every type of possible animal. It would be better to implement it in the classes that implement Animal. Then a horse class won't have to know about tigers or bears.
So I should make the reproducing method abstract in the house class and implement it through my subclasses?
Also, I noticed that if I do "reproduction(otherAnimal) == true" I will have infinite reproducing. How can I go about fixing that?
Borg
2,312
Did you mean the Animal class? Then yes.
Why do you think that? Maybe I'm not following what you're writing it at this point. Can you post your current code as we've discussed?
Opps, I meant Animal. Thank you!
For example, if one animal can reproduce with another, I want to limit the chance of reproduction somehow such that I won't have infinite reproduction, e.g.
if ((((reproduction(otherAnimal) == true) == true) == true) == true).
Because I was told to never compare a boolean expression with a boolean literal.
Borg
2,312
I don't think that it will be a problem. For now, can you scope out what you think the reproduction(otherAnimal) method will look like if you implement it inside of a Horse class?
If I implement it in a subclass of a Animal which is called Horse then I will have to override the reproduction method to reproduce with, lets say with a class of Donkeys, but with no other subclass of Animal. And each subclass of Animal can only reproduce with animals that are predetermined.
Borg
2,312
The reproduction method takes an Animal class. You can pass any animal in. A donkey is just another type of animal. Also, keep in mind that the otherAnimal object isn't a donkey or a tiger or a bear. It's an Animal.
I see, thank you!
Borg
2,312
I see, thank you!
You're welcome. I'll be interested to see the final result. :smile:
Likes Robben
Will do! It might take me awhile because it's a long code (most likely tomorrow) but I definitely post it once I am done.
Related Threads on Abstract Class return
  • Last Post
  • Last Post
12K
