Help on AC Circuits: Power Factor = 1.0
In summary, the conversation is about a motor attached to a 120 V/60 Hz power line and drawing an 8.50 A current with an average energy dissipation of 800 W. The speaker has correctly answered the first three parts of a question about the motor, but is struggling with the fourth part which asks for the amount of series capacitance needed to increase the power factor to 1.0. The speaker explains that they know the resistance and total impedance, and need to find a capacitance that cancels out the inductive impedance at 60 Hz to achieve a power factor of 1.0.
RagincajunLA
Hey guys I just need some help on something
The question is: A motor attached to a 120 V/60 Hz power line draws an 8.50 A current. Its average energy dissipation is 800 W.
I got the first 3 parts of this question correct...
1. What is the power factor
ans = .784
2. What is the rms resistor voltage?
ans = 94.1 V
3. What is the motor's resistance?
ans = 11.1 ohms
now all of these answers are right but i can't seem to get the last one and it is...
4. How much series capacitance needs to be added to increase the power factor to 1.0?
I'm assuming 120V and 8.5A are also RMS. It's been a while, but it's the only thing that makes sense with 800W. If either one is peak-to-peak, that'd give you power factor that's greater than 1.0 and that's nonsense. Anyways...
You know the resistance. You know the total magnitude of the impedance, because you have voltage to current ratio. So you can compute inductive component of the impedance. Now all you have to do is find the capacitance such that capacitive impedance at 60Hz cancels your inductive impedance. Then the net impedance of the motor is just the resistance, and your power factor becomes 1.0.
What is power factor and why is it important in AC circuits?
Power factor is a measure of how effectively a circuit uses electrical power. It is important in AC circuits because it affects the efficiency of the circuit and can impact the quality of the power supply.
How do you calculate power factor?
Power factor is calculated by dividing the real power (measured in watts) by the apparent power (measured in volt-amperes). This ratio can also be expressed as the cosine of the phase angle between the voltage and current in the circuit.
What is the ideal power factor?
The ideal power factor is 1.0, which means that the real power and apparent power are equal and there is no phase difference between voltage and current. This indicates maximum efficiency in the circuit.
What causes a low power factor?
A low power factor can be caused by inductive loads, such as motors and transformers, which draw more current than is necessary for the amount of real power they require. This leads to a phase difference between voltage and current, resulting in a lower power factor.
How can a low power factor be improved?
A low power factor can be improved by adding power factor correction devices, such as capacitors, to the circuit. These devices can offset the effects of inductive loads and bring the power factor closer to 1.0. It is also important to properly size and balance loads in the circuit to improve power factor.
  • Electrical Engineering
