AC current on a Inductor
SimpliciusH
33
An alternating current is running through a serially connected inductor(L) and resistor(R). The alternating voltage causing it is:
[URL]http://upload.wikimedia.org/math/5/a/0/5a0ecaa1432c6cdce653a943b4962a21.png[/URL]
How does the voltage on the inductor change over time?
Kirchhoff's cricuit laws [tex]v_{g}=v_{L}+v_{R}[/tex]
If I understand the text right, overall I should be searching for the [tex]v_{L}(t)[/tex] function right?
Ok so I know that
[tex]v_{L}=L \frac{dI}{dt}[/tex]
[tex]v_{R}=IR[/tex]
therefore
[tex]\frac{dI}{dt}+\frac{R}{L}I=\frac{1}{L}\frac{dv_{g}(t)}{dt}[/tex]
and this is where I get stuck. Thanks for any help!
Answers and Replies
ehild
15,543
1,915
It should be 1/L vg on the right-hand side of the final equation. Assume I(t) in the form of I0sin(ωt+φ) take the derivative and substitute it for dI/dt into the equation.
ehild
SimpliciusH
33
Integrate the whole thing? Like this:
[tex]I_{0}\omega cos(\omega t + \varphi)+I_{0}\frac{R}{L}\frac{sin(\omega t + \varphi)-\omega t cos(\omega t + \varphi)}{\omega^2}=\frac{1}{L}V_{peak}\frac{R}{L}\frac{sin(\omega t)-\omega t cos(\omega t)}{\omega^2}[/tex]
Is this right?
ehild
15,543
1,915
vg is given: vg=Vpeaksin(ωt).
Apply the sum rule to sin(ωt+φ) and cos(ωt+φ). Collect like terms. Take into account that the equation holds for any time.
There is an easier way to solve the problem, using complex impedance or phasor diagram. Have you heard about them?
ehild
SimpliciusH
33
ehild
Is this comment meant for the last version of the response?
I edited my response extensively before I noticed your reply, I now realized I should have just made a new post, since this ultimately confused me and makes communication difficult. Sorry, won't do it again.
ehild
I've heard of them but haven't used either before.
SimpliciusH
33
Is this right?
This is just so many kinds of wrong... :(
This is what I meant to write:
[tex]I_{0}sin(\omega t + \varphi) + \frac{RI_{0}}{L}(-\frac{cos{\omega t+\varphi}{\omega}= \frac{1}{L} V_{peak} sin (\omega t) [/tex]
ehild
15,543
1,915
Do not integrate anything. Use the sum rules:
sin(ωt+φ)=sin(ωt)cosφ+cos(ωt)sinφ and
cos(ωt+φ)=cos(ωt)cosφ-sin(ωt)sinφ.
Collect the terms with cos(ωt), and do the same with the terms containing sin(ωt).
ehild
SimpliciusH
33
Apply the sum rule to sin(ωt+φ) and . Collect like terms. Take into account that the equation holds for any time.
Did you mean the trig sum rule?
Edit:
ehild
It dawned on me a minute too late. :) Thank you for being so patient!
SimpliciusH
33
V0=Vpeak
So I go from:
LI0cos(ωt+φ)+RI0sin(ωt+φ)=V0sin(ωt)
To:
LI0cos(ωt)cosφ - LI0sin(ωt)sinφ + RI0sin(ωt)cosφ + RI0cos(ωt)sinφ = V0sin(ωt)
And collect the terms:
RI0sin(ωt)cosφ - LI0sin(ωt)sinφ - V0sin(ωt)+ RI0cos(ωt)sinφ + LI0cos(ωt)cosφ = 0
sin(ωt)(RI0cosφ - LI0sinφ - V0)+ cos(ωt)(RI0sinφ + LI0cosφ) = 0
sin(ωt)(Rcosφ - Lsinφ)+ cos(ωt)(Rsinφ + Lcosφ) = sin(ωt)V0/I0
Do I now find the φ for which this equation is true? V0 seems to be causing me problems there.
SimpliciusH
33
Ok I've simplified it to:
[tex]Lcos(t\omega + \varphi)+Lsin(t\omega + \varphi)=sin(t\omega + \varphi)\frac{V_{0}}{I_{0}}[/tex]
ehild
15,543
1,915
You forgot that ω should be together with L.
The equation has to be true for any time t, that is for such values of t when sin(ωt)=0 (and cos (ωt)=±1) and also for such values when cos(ωt) =0 (and sin(ωt) =±1). This means that
Rsinφ + Lωcosφ=0 (*)
and
Rcosφ - Lωsinφ=V0/I0 (**)
You get φ from (*). Taking the square of both (*) and (**) and adding them up, the sinφ and cosφ terms cancel and you get an equation for I0.
ehild
ehild
15,543
1,915
That is wrong. Go back to your previous post. I answered it.
ehild
SimpliciusH
33
and
ehild
Ok I get 2*pi+pi for the value of φ
and V0/(R2+L22*cos(2*φ) for I0)
SimpliciusH
33
I then assume put this back into the equation for VL, and derive it, I get:
V0*L/(R2+L22*cos(2*φ) times ωcos (ωt + φ)
or should I say times -ωcos (ωt) considering the value of φ.
Is this right?
ehild
15,543
1,915
No. φ is not 2*pi + pi, and why do you write 3*pi in this way?
Rsinφ + Lωcosφ=0. What is tanφ then?
To get an expression for I0 square the equations
Rsinφ + Lωcosφ=0
and
and add them together. Take care of the + and - signs.
ehild
Deric Boyle
51
SimpliciusH you need to practice trigonometry.
I recommend Trigonometry by S.L. Loney to you (It's a must for you)
Suggested for: AC current on a Inductor
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
