• Support PF! Buy your school textbooks, materials and every day products Here!
AC RLC circuit.
  • Engineering
  • Thread starter Mutaja
The AC circuit is the following:
Vin = 10√2*sinωt V
R = 5 Ω
L = 5 mH
C = 100 µF
a) what is Vout when the frequency (f) is 100hZ
After two weeks of spring break in addition to Easter holiday, I'm well and truly out of shape when it comes to 'homework'.
I need to solve this, simply because it's relevant to what I study. My book covers just about anything, but I can't seem to find examples on how to solve this - it might be because I'm not sure what I'm looking for.
I'm looking to find the Vout. The problem with this is my understanding of how voltage works. Voltage is something that's across a component, and in that case, Vout will be equal to VR in my circuit above, right?
I also can't find any formulas in my book that covers this topic. I'm fully aware that's because I can't find it - I know it's there. I would just like some guidance as to where I can start solving this. I will continue looking through my book in addition to using google.
Thanks for any input, and I apologize for this vague question - I just need to get started after spending too long off the subject.
Answers and Replies
gneill
Mentor
20,796
2,775
The "LC" leg and the R form a voltage divider. So:
Look up the formulas for the impedances of reactive components (inductors, capacitors).
Look up the formula for a voltage divider.
Alright.
Impedance for inductors: XL = ωL
Impedance for capacitors: XC = [itex]\frac{1}{ωC}[/itex]
Voltage divider rule for AC circuits: VZX= [itex]\frac{ZX}{ZT}[/itex] * VT
ZX being the impedance of the component I'm calculating the voltage drop across.
ZT is the total impedance of the circuit.
VT would be supplied voltage, in this case, VIN
So here's my attempt:
ZT = XC + XL + R
ZT = [itex]\frac{1}{ωC}[/itex] + ωL + R
ZT = [itex]\frac{1}{2∏*100Hz*100μC}[/itex] + 2∏*100Hz*5mH + 5Ω
ZT = 15.91Ω + 3.14Ω + 5Ω
ZT = 24.05 Ω
ZX = 15.91Ω + 3.14Ω
ZX = 19.05Ω
VOUT = [itex]\frac{ZX}{ZT}[/itex] * VIN
VOUT = [itex]\frac{24.05Ω}{19.05Ω}[/itex] * 10*√2*sinωtV
VOUT = 1.26 * 10*√2*sinωtV
Things are starting to make sense again, and I got to say, I really enjoy doing this. Progress is king.
Assuming some of the above work is correct, I have a couple of questions. t is the time constant of the sinus wave. When t is 0, the voltage is 0. Should my answer then be VOUT(t) = 17.82sinωtV ?
Also, isn't AC voltage/current given in complex numbers? Sorry for the stupid questions. Hopefully I'll get back into this soon enough :)
Really appreciate your help, gneill.
gneill
Mentor
20,796
2,775
Alright.
Those are reactances, the magnitude of the impedances which are complex values. So what you want are:
Impedance for inductors: XL = jωL
Impedance for capacitors: XC = [itex]\frac{1}{jωC}[/itex]
Complex values are used because they represent phasor values, and phasors are what you want to work with for AC circuits. Let's you determine not only the magnitudes of currents and voltages but their relative phases, too.
ZT = XC + XL + R
ZT = 24.05 Ω
ZX = 15.91Ω + 3.14Ω
ZX = 19.05Ω
t is the time variable for the time-domain representation of the voltage (or current) waveform. If 17.82V turns out to be magnitude of the voltage waveform at the output, then you'll write it as you did, but the sin function will also have a phase angle since the reactive components will impose a phase shift. So, supposing A is the magnitude and ##\phi## the phase angle:
##V_{out} = A \ sin(ω t + \phi)##
Yup. You'll want to take another look at your calculations and use complex values for the impedances.
When I implement j to my equations, I get:
ZT = j 15.91Ω + j 3.14Ω + 5Ω
I add the complex numbers together, and convert to polar form:
19.695Ω 75.29°.
When I want to find ZX, I subtract 5Ω from the equation, and end up with arctan(19.05/0).
Where am I going wrong now?
Edit: I will have another attempt soon.
XL = jωL = j3.14Ω
XC = [itex]\frac{1}{jωC}[/itex] = -j15.91Ω
ZT = 5Ω -j12.77Ω -> 13.714Ω - 68.6175°
ZX = -j12.77Ω -> 12.77Ω -90°
VOUT [itex]\frac{ZX}{ZT}[/itex] * VIN
[itex]\frac{12.77 -90°}{13.714 -68.6175°}[/itex] * 10√2sinωtV
VOUT = 0.91*10√2sin(ωt - 21.38°)
VOUT = 12.87sin(ωt - 21.38°)
Am I onto something here?
gneill
Mentor
20,796
2,775
Whoops. Check the value for the capacitor impedance. Note that a capacitor has a negative impedance (the "j" is in the denominator of the impedance calculation, so when it's promoted to the numerator it changes sign).
The rest of your calculations look okay (at a glance) at least as far as procedure goes. Redo them with the new capacitor impedance value.
I'm pretty sure I did that. My edit is somewhat hidden.
There are a couple of "thinkers" attached to this problem. Those are resonance frequency, band width and power limits for R within BW. These are just small problems we should consider, but don't have to do. I've given it a try regardless, and here's what I ended up with:
Resonance frequency:
fR = [itex]\frac{1}{2∏√(LC)}[/itex]
= 225hZ
Band width: fC2-fC1 = [itex]\frac{R}{2∏L}[/itex]
= 159.15
Power limits: I have no idea about this one as it's supposed to be within my BW. My BW is a given constant. It has no range of values.
This isn't very important, I just wanted to make sure I've touched upon it. If you have any guidance, I'd appreciate it as always.
Thanks a bunch for your help with the above problem regardless. I probably would've lost interest for this subject if it weren't for this forum. Now it's my favorite one.
gneill
Mentor
20,796
2,775
Okay, well I only saw the version where the capacitive impedance was given as j15.91Ω , which threw off your impedance magnitude and angle, and hence the remainder of the calculations. If you've fixed that, no problem. But I can't check what I can't see :smile:
= 225hZ
= 159.15
Your resonant frequency and bandwidth calculations look okay.
Not sure what they mean by "power limits", unless the components (the resistor in particular) have power ratings.
Good to hear!
My problem statement ask for this:
Calculate the upper and lower (max and min) power limit for R, if the frequency is within BW.
Power limit might be a bad translation on my part, as I can't find anything in my book regarding this.
No biggie, though. I will ask my lecturer after our spring break :)
gneill
Mentor
20,796
2,775
Okay, so it looks like you'll need to find the minimum and maximum RMS output voltage between the bandwidth frequency limits. Use this with the known resistance value to find the powers.
You should be able to use knowledge of what happens to the reactive impedance at resonance and the definition of cutoff (or corner) frequency as shortcuts.
Related Threads on AC RLC circuit.
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
