Collision of Two Cars with Constant Velocity and Deceleration
In summary, the problem involves two cars, A and B, traveling at a constant velocity of 20 m/s along a road. Car A is 15m behind Car B. When they reach point P, both cars decelerate at 4m/s^2. The task is to determine if and when the two cars will collide and to draw a speed-time graph of their motion. To solve this problem, one must first find the time difference between when each car starts to decelerate. Using this, one can draw a speed-time graph and locate the point at which the area under the graph for Car A is exactly 5 less than the area for Car B. This will determine the distance from P at which the collision
mcintyre_ie
66
Hey
Id really appreciate any help anybody can give me with this problem, its urgently needed and very very important, I've been stuck on it for about an hour and don't even know where to start:
Two cars A and B, each 5m in length, travel with constant velocity 20 m/s along a straight level road. The front of car A is 15m directly behind the rear of car B. Immediately on reaching a point P, each car decelerates at 4m/s^2.
1) Show that A collides with B
2) At what distance from P does the collision occur?
3) Show the motion of both cars on the same speed-time graph.
Thanks in advance for any help you can give
What you need to do first is to translate the "when they reach P" business to a time difference. Indeed, this problem is probably easier if you do part 3 first.
From the data given, it is clear that the two cars are 20m apart, considering their middles or both their fronts etc. Therefore, when car B passes P, car A will be 20m from it. Using the velocity it gave you, you can then find the time difference between the two reactions, and you can easily draw a speed time graph from this.
So, you know that the area under the speed time graph is distance, right? In this case, you can consider the area for B as a trapezium (Using equation area = 0.5 * h * (a+b)), and for A as a rectangle and a trapezium. Now, just locate situation at which the area for A is exactly 5 less than the area for B (Since we are considering the middles of cars in the graph, not the relative distance from front and rear) Then that's 1 and 2 sorted.
If you wanted though, you could have split the situation up as before and applied formulae like s = ut + 0.5 at^2... but that's probably overcomplicating.
FZ+ You can't imagine how grateful i am for your help... I've been trying to do this one question for like an hour, but couldn't figure out what i was supposed to do with the info given, its very different to our normal exam questions.
Using the velocity it gave you, you can then find the time difference between the two reactions, and you can easily draw a speed time graph from this."
Which reactions would i be finding the time-difference for?
I am unfamiliar with the "trapezium" things, i guess I've never met the technical term for whatever it is,
The laws are the way we usually try and attept it, and to be honest, I am still a bit lost, so if you could just give me over-tired brain another few hints i would be sooooooooooooooo grateful
Thanks for the help so far too by the way!
The time at which car B starts deaccelerating, and car A starts deaccelerating...
Imagine a rectangle, but with the lengths of the sides different. ie. a quadrilateral (four sided shape) with two parallel sides...
Horrific ascii art follows...
Code:
is a trapezium.
Funnily enough though, the equations you usually get given are derived effectively working out the area, but a mathematical method known as calculus.
But no matter...
If you look at the motion of car B, you can see that it follows an equation for uniform decceleration,
s = ut + 0.5 a t ^ 2
Meanwhile, the other car undergoes a bit of constant velocity first, and then switches to uniform acceleration. The other car begins with a 15 metre lead between the front and rear, but also a 20/u second head start. But u is also reduced by v = u + at
So, at time t (starting from when the second car A crosses the point), the distance car A is behind car B is given by distance = (u + a)(t + 1) + 0.5 a(t + 1)^2 - u(t) - 0.5 a(t) ^2 + 15.
When distance = 0, then there is the collision. Feed the calculated t back into the mix...
OK... I probably confused myself back there, so check my method...
What is accelerated linear motion?
Accelerated linear motion is the movement of an object in a straight line with a constant increase in velocity over time.
What causes accelerated linear motion?
Accelerated linear motion is caused by a force acting on an object, such as gravity or a push or pull from another object.
How is accelerated linear motion measured?
Accelerated linear motion can be measured by calculating the average velocity of an object over a specific time period or by measuring the displacement of the object over time.
What is the difference between accelerated and uniform linear motion?
In accelerated linear motion, the velocity of an object changes over time, while in uniform linear motion, the velocity remains constant. Accelerated motion is also characterized by a non-zero net force acting on the object.
What are some real-life examples of accelerated linear motion?
Some examples of accelerated linear motion include a ball rolling down a ramp, a car accelerating from a stop, and a rocket launching into space.
