Twin Paradox: Accelerating Rocket Ship from Earth in 2100
  • Thread starter sludgethrower
  • Tags
    Accelerating
In summary, the conversation discusses a thought experiment involving a rocket ship traveling for 5 years, decelerating, turning around and returning to Earth. One of the twins on the rocket is 40 years old and the other twin remains on Earth. The conversation delves into the concept of relativity and how it can create paradoxes such as the twin paradox. The conversation also touches on the use of velocity and proper time in measuring distance and how it can affect the perception of speed.
sludgethrower
Assume that a rocket ship leaves the Earth in the year 2100. One of a set of twins born in 2080 remains on the Earth (inertial frame); the other rides in the rocket. The rocket ship is so constructed that is has an acceleration g in its own rest frame (this makes the occupants feel at home). It accelerates in a straight-line path for 5 years (by its own clocks), decelerates at the same rate for 5 more years, turns around, accelerates for 5 years, decelerates for 5 years, and lands on earth. The twin in the rocket is 40 years old.
(a) What year is it on earth?
(b) How far away from the Earth did the rocket ship travel?
I managed to find solutions for this problem...but they seemed paradoxical, not for the reason that the moving observer appears to time travel - that is perfectly legitimate. While in the frame of the earth, the quotient of the outward distance and time was less than c - no problems there. However, I then asked myself "what if the observer during the accelerating portion of the journey decides to stop accelerating and continue in an intertial reference frame?". Both observers are now intertial, and thus must agree on the distance between them: my results say otherwise. In fact they show that the distance between them, divided by the time on the moving observors clock can be greater than c.
I think the paradox may arise at my assumption that we can see the outward journey as a series of interial rest frames of the rocket. Or perhaps my calulations are correct, up until the point where the rocket stops accelerating: it could be that the deceleration must occur in finite time...
Anyway, I will not post my solutions (yet), so that anyone who wants to can have a go at the problem themselves. If you want to, you are very welcome to find how the Earth appears to the observer in the rocket.
Not true, they'd only agree on the distance if they were at rest relative to one another--inertial observers in motion relative to one another can disagree on the answer to questions like "how far apart were we at the moment observer #1 turned 30". You can think of this in terms of the fact that each uses a ruler-clock system at rest relative to themselves to measure distance, and each observer thinks the other observer's ruler is shrunk due to Lorentz contraction, and the other observer's clocks are out-of-sync due to the relativity of simultaneity (you need synchronized clocks to measure distance at a single moment).
Yes, I see. Although this only partially resolves my paradox. I am still wondering why my rocket observer looks back and measures a distance from the Earth that when divided by the time on his clock is greater than c...
How is this any different from the standard twin paradox?
I see. I think what I meant is that each observer records the same distance between them at the time when he notices the other observer stops accelerating. But, I see this may not be true, since the two observers are not in a symmetrical setup. One cannot just suppose that the rocket is inertial and take the frame of the observer on Earth as accelerating. The observer certainly feels the acceleration, and walks as if on earth. I thought that I had resolved this by letting the rocket observer continue in an inertial frame, but I suppose that an amount of antisymmetry has now built up.
It is the standard twin paradox. But these "paradoxes" aren't really paradoxes...and are usually down to some non-relativistic assumption that has been made - but perhaps hidden. It is rather like the "paradox" that a man can manage to fit a 10 foot ladder into a 5 foot long garage by traveling fast enough into the garage. However, taking the frame of the man...he sees himself trying to fit his ladder into a contracted garage. This isn't a paradox...but one has to really probe why it isn't...which I will leave you to do if you haven't met the problem before...
Velocity is defined as distance divided by time, each measured in the same inertial frame:
[tex]v=\frac{dx}{dt}[/tex]
What you are doing here is basically measuring distance in the original inertial frame, and dividing by the proper time of the accelerating twin. For short timscales:
[tex]u=\frac{dx}{d\tau}=\gamma \frac{dx}{dt}[/tex]
u is also a useful quantity, for example it is a component of the four velocity, but it is not "velocity" or "speed".
If you ever heard about galaxies receding "faster than the speed of light": that's a similar definition.
I don't think that is what I was doing.
For the accelerating observer, I was calulating the distance from the Earth by using an integral over the instantaneous rest frame differentials...
For the Earth observer I used his own personal time, not the proper time, in my calculations...
It is probably ssmething fishy with my maths...
Proper time is own personal time.
Whatever, the "paradox" persists if you wait until the accelerating twin is at rest wrt the Earth (at the turnaround point), and also if you neglect acceleration and simly move away with constant speed. That's what I am referring to.
There are two "proper times" in this question...I was referring to the proper time of the Earth observer, trying to distinguish it from the proper time of the rocket observer.
I was approximating the outward journey into an "infinite" number of rest frames of the rocket. In each infinitesimal frame, I would spend an "infinitesimal" amount of proper time. I would then caclulate the infinitesimal distance that the Earth appeared to recede during this time. I then summed over these differentials using an integral.
I know what I have done wrong. This integral does not correspond to anything physically useful. I have failed to account for the Lorentz contraction of the distance that had already been travelled. But I could get around this, if I multiply each of the differential elements of distance by an appropriate gamma factor. This gamma factor would have to be different for each differential length, since each instantaneous frame would be traveling at a different speed relative to the frame in which I want to find this distance...
1. What is the Twin Paradox?
The Twin Paradox, also known as the Twin Paradox of Special Relativity, is a thought experiment that explores the effects of time dilation on a pair of twins where one twin travels at high speeds in a rocket ship while the other stays on Earth. It highlights the concept that time is relative and can pass at different rates depending on the observer's frame of reference.
2. How does the Twin Paradox relate to Special Relativity?
The Twin Paradox is a thought experiment that demonstrates the principles of Special Relativity, which is a theory proposed by Albert Einstein that explains how time and space are relative and can be affected by factors such as velocity and gravity. The thought experiment shows that time can pass at different rates for observers in different frames of reference, and that the perception of time is not absolute but rather depends on the observer's relative motion.
3. What happens in the Twin Paradox thought experiment?
In the thought experiment, one twin stays on Earth while the other twin travels in a rocket ship at high speeds. When the traveling twin returns to Earth, they will have aged less than the twin who stayed on Earth due to the effects of time dilation. This means that time for the traveling twin has passed slower than for the twin who stayed on Earth. This is a result of the traveling twin's frame of reference being in motion at high speeds, causing time to pass slower for them.
4. Does the Twin Paradox really happen in real life?
While the Twin Paradox is a thought experiment, it has been observed and verified in experiments involving atomic clocks and high-speed particles. The effects of time dilation have been proven to be real and are a fundamental aspect of Special Relativity. However, the scenario depicted in the thought experiment is not practical or possible in real life as it would require traveling at speeds close to the speed of light, which is not currently achievable.
5. What is the significance of the Twin Paradox?
The Twin Paradox highlights the concept of time dilation and the relativity of time, which are fundamental principles in modern physics. It also challenges our understanding of time as a fixed and absolute concept, and instead shows that it can be affected by factors such as velocity. The thought experiment has also been used to explain other phenomena, such as the aging of astronauts in space and the concept of time travel.
