What is the Acceleration and Force of a Crate Being Pulled Across Ice?
In summary: In this case, since the crate is only moving horizontally and the force is applied at an angle, you need to use the horizontal component of the force to calculate the acceleration. In summary, to calculate the acceleration of a 50-kg crate being pulled across ice with a rope, a force of 80 N applied at an angle of 36° with the horizontal, one would use the horizontal component of the force (64.72 N) and the equation F=ma. The resulting acceleration would be 1.2944 m/s.
halo9909
37
A 50-kg crate is pulled across the ice with a rope. A force of 80 N is applied at an angle of 36° with the horizontal. Neglecting friction, calculate
(a) the acceleration of the crate.
m/s2
(b) the upward force the ice exerts on the crate as it is pulled.
F=Ma
law of Cosines
law of sines
I have the upward force "Fay" which is 443N
using the law of sines 80sin36 = 443N which is the vertical force and usig the law of cosines the horizontal is 64.72N
I am not sure how to calculate the acceleration
Use F=ma. What is the force acting on the crate in the horizontal direction? That is the force that is causing the crate to accelerate.
oh wow thanks
so you use the "horizontal" force and with F=ma
the horizontal force of 64.72=50kg *a
it becomes 1.2944m/s
So you would always use the horizontal force to the ground for accleration or only in this case?
Since the crate is only moving in the horizontal direction (so it isn't rising falling - it stays in constant contact with the ice) the acceleration is only in the horizontal direction. I wouldn't say you always use the horizontal force, it depends on the situation.
What is acceleration?
Acceleration is the rate at which an object's velocity changes over time. It is a vector quantity, meaning it has both magnitude (speed) and direction.
What is the formula for acceleration?
The formula for acceleration is a = (v2 - v1) / t, where a is acceleration, v2 is the final velocity, v1 is the initial velocity, and t is the time taken for the change in velocity to occur.
What is Newton's Second Law of Motion?
Newton's Second Law of Motion states that the force acting on an object is equal to its mass multiplied by its acceleration. This can be represented by the equation F = ma, where F is force, m is mass, and a is acceleration.
How does force affect acceleration?
The greater the force applied to an object, the greater its acceleration will be. This is because force is directly proportional to acceleration, according to Newton's Second Law.
What are some examples of forces that can cause acceleration?
Some examples of forces that can cause acceleration include gravity, friction, and applied forces such as pushing or pulling an object. These forces can either increase or decrease an object's acceleration depending on their direction and magnitude.
