Acceleration and Forces
I am just looking for some good explanations (or references) to a problem about acceleration. If a person is sitting in a car and the car accelerates then, conceptually, does the weight of the person pushing into the seat increase, decrease, or remain the same?
I extend my thanks to anyone that helps me out.
Answers and Replies
Hootenanny
Staff Emeritus
Welcome to the forums,
The weight (look up the definition of weight) will remain constant, however, the normal reaction force exerted by the chair on the person (and hence the person on the chair) will change. You could start by drawing a FBD in order to examine all the forces acting.
D H
Staff Emeritus
Insights Author
15,393
686
There are two definitions of weight: "actual weight" and "apparent weight". The "actual weight" of an object is defined as the force on an object due to gravity. The "apparent weight" of an object is the sum of all forces on an object except for gravity. The "actual weight" of a person in a car does not change when the car accelerates. The "apparent weight" does change.
Since force is a vector, so is weight. For an object on the Earth, the "actual weight" vector approximately points toward the center of the Earth while the "apparent weight" points outward. Your bathroom scale (and any device that measures weight, such as an accelerometer) measures "apparent weight", not "actual weight". Actual weight is not measurable. It can only be inferred.
Related Threads on Acceleration and Forces
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
V
  • Last Post
  • Last Post
  • Last Post
