Acceleration Graph: Answer 5 Correct?
In summary, the acceleration towards the Earth is positive, and this causes the initial velocity to decrease and become zero at some height after the U-turn object travels towards Earth. This causes the velocity to increase.
Manasan3010
38
I chose Answer 5 but the given answer was 1. Am I correct or what was the mistake?
What is your reasoning for choosing 5?
Answer 5 shows an initial negative acceleration (away from the Earth according to the question) with an instantaneous jump to a positive acceleration. Is that how gravity works?
The acceleration towards the Earth ip positive so when we throw the ball in opposite direction acceleration will be negative and this causes the initial velocity to decrease and become zero at some height after the U-turn object travels towards Earth which causes positive acceleration hence the velocity increases.
I think the instantaneous jump to a positive acceleration is caused at the point where object starts to return to the Earth from air.
Why? Does the direction of acceleration depend on the velocity?
Note that acceleration is rekated to the change in velocity, not to the change in speed.
Note that acceleration is related to the change in velocity, not to the change in speed.
Have a look at this link
Please explain me the answer I am so confused :(
acceleration is due to a force. which force do you think is acting upon the particle?
That is not how this forum works. You have been given several hints as to how to think about this problem. It is better for your long time learning to consider those hints and their implications. If you are still confused after that, you need to specify what confuses you and why. You will not be handed the answer on a platter because that is not a good way of learning.
Let me talk a little in general about velocity and acceleration and what direction changes are in.
You know that ##a = \Delta v/\Delta t##. If ##\Delta v## is positive that means ##v## increased. An increase could be going from 0 to 3, or from 2 to 5, or from -1 to +1, or from -5 to -2.
[No, I'm not putting units on these, even though I'm a guy who always complains when students leave units off. The reason is that these remarks are true for any units.]
In particular study those last two examples. The final velocity minus the initial velocity is positive. Those are all changes which go to the right on the number line. Those are situations in which ##\Delta v## is positive. Going from -1 to +1 is an increase in velocity (not in speed, and here is why your instructors make a distinction between speed and velocity). The velocity is getting more positive. It is moving in a positive direction. The acceleration is positive.
In the same way, ##\Delta v## negative means ##v## is getting more negative. So that could be going from +5 to +2. But it could also be going from +1 to -2, or from -2 to -5. Those are all negative accelerations.
Here's one other principle to keep in mind: ##F = ma##. That means ##a = F/m##. What does that tell you about the relationship between the direction of F and the direction of a? Remember m is always positive.
If you are confused by what is said in any of our posts, likely any of us that are connected could explain/reword the post for you. We don't explain how to get the answer, but if necessary we can explain posts that have come in for you.
In graphs of a thrown ball, assume that time starts when the ball leaves the hand. So would the acceleration of the throwing motion be part of the graph?
Thank You guys I understand now. I think the reason I chose Answer 5 was because I got confused with the direction of motion and I also forget that Gravitational acceleration will be same no matter what the direction of motion is.
What is an acceleration graph?
An acceleration graph is a visual representation of an object's acceleration over time. It shows how the velocity of an object changes over time, and can also indicate the direction of the acceleration.
How is an acceleration graph different from a velocity graph?
An acceleration graph shows the rate at which an object's velocity is changing, while a velocity graph shows the actual velocity of the object at a given time.
What is the slope of an acceleration graph?
The slope of an acceleration graph represents the object's acceleration. A steeper slope indicates a higher acceleration, while a flatter slope indicates a lower acceleration.
How do you calculate acceleration from an acceleration graph?
Acceleration can be calculated by finding the slope of the acceleration graph. This can be done by dividing the change in velocity by the change in time.
How can an acceleration graph be used to predict an object's motion?
By analyzing the shape and slope of an acceleration graph, we can predict how an object will move in the future. A positive slope indicates a speeding up motion, while a negative slope indicates a slowing down motion. A flat line indicates a constant velocity.
