Acceleration of a tire rolling
In summary, a tire rolls with radius r. The CM of the wheel travels at a velocity of vcom. Relative to a passenger in the car and to a street sign on the street, the top and bottom of the wheel are traveling at a velocity of vcom and -vcom. So the magnitudes of both accelerations are vcom^2/r.
So a tire rolls with radius r. The CM of the wheel travels at a velocity of vcom.
What is the acceleration of the top of the wheel and the bottom of the wheel relative to a passenger in the car and to a street sign on the street?
a = v^2/r
Relative to the passenger, the top and bottom of the wheel are traveling at a velocity of vcom and -vcom. So the magnitudes of both accelerations are vcom^2/r.
Relative to the street sign, the top of the wheel is traveling at 2vcom. The bottom of the wheel is traveling at 0. I know that these are the wrong velocities to plug into the equation a = v^2/r since the answer for the accelerations are the same as the accelerations in the previous situation.
A friend told me that centripetal acceleration is always relative to the axle. I thought that perhaps since the translational acceleration of the top and bottom of the wheel are 0, and since the acceleration of the wheel when it is rotating is vcom^2/r for the top and bottom, the magnitudes of the accelerations of both the top and bottom could be Arotation + Atranslational = ARolling,
which would be vcom^2/r.
Are any of these explanations correct?
Relative to the sign post, the CM travels with constant velocity. The tire rotates around an axis through the CM and travels also with the same velocity as the CM. It keeps this component of velocity, so any change of the velocity of the tire comes from the rotation. Therefore the only acceleration is the centripetal one, which magnitude is related to the speed of the tyre with respect to the axis. So its magnitude is vcom^2/r, the direction points inward, towards the CM.
ehild
Okay, the centripetal acceleration is relative to the axis. Is centrip. acceleration always relative to the axis or is it because in this case centrip. acceleration is the only acceleration acting on the wheel?
hi joej24! :smile:
(try using the X2 icon just above the Reply box :wink:)
rubbish!
acceleration is acceleration!
it isn't relative to any point
(it is of course relative to velocity, but not to any point at that velocity)
when dr/dt = 0, the acceleration perpendicular to the velocity is always speed2/r, where r is the radius of curvature of that piece of the wheel
(perhaps your friend meant that v2/r is always relative to the centre of curvature?)
in this case, relative to a stationary observer, the speed (for the top of the wheel) is 2v, but the r is unknown to you (unless you're familiar with the geometry of a cycloid :wink:) …
that's why it's much easier to choose a frame in which you know the radius of curvature without having to do complicated geometry! :biggrin:
ok, now here's a fun test for you …
what is the radius of curvature of the path (relative to the ground) of the piece of metal presently (a) at the top of the wheel (b) at the bottom of the wheel? :wink:
Is the radius of curvature the same as the distance from a point to the center, or point of rotation? In that case
(a) r
(b) r
no
a point on the rim of a wheel traces out a cycloid
see the pretty picture at the top of http://en.wikipedia.org/wiki/Cycloid" [Broken] …
you need the radius of curvature at the top and bottom of that cycloid :wink:
2r and 0, which concur with the wheel's velocity relative to the ground, 2v for the top and 0 for the bottom. But it doesn't make sense that the acceleration of the top is
(2v)2 / 2r
and
02 / 0
for the bottom
(2v)2 / 2r
and
02 / 0
for the bottom
The radius of curvature of the cycloid is 4r.
Although, the point of contact at the bottom of the tire is is stationary for an instant, immediately before contact the point moves vertically downward, immediately after contact it moves vertically upward.
v2/r is the normal component of acceleration (an) of a selected point on the tire along the cycloid, and r is the radius of the curvature of the cycloid at the selected point. But the acceleration at that point has also tangential component at which is the time derivative of the speed. The magnitude of the overall acceleration was asked, it is √(at2+an2).
The calculation is quite tiresome but you will have the result that the magnitude of acceleration is the same in both systems with respect to the car and with respect to the ground.
It is the consequence of Newton laws: all inertial frames of reference are equivalent, the forces do not change if you choose an other frame of reference. The same holds for the acceleration.
One frame of reference ( the car) moves with velocity V with respect to the other one (ground). An object (one piece of the tire) moves with velocity v' in the moving frame of reference. The velocity of the object seen from the frame of reference in rest is v=V+v'. The acceleration is the time derivative of the velocity. As V is constant, dv/dt = dv'/dt, the acceleration is the same in both inertial frames of reference, car and ground.
ehild
hi joej24! :smile:
(just got up :zzz: …)
(2v)2 / 2r
no, you're using "r" to mean two different things
since i was the one who set the problem, i think it's ok if i give the answer :wink:
we know from the moving frame that (at the top of the wheel) a = v2/r
we know that a in the stationary frame must be the same
and we know that the radius of curvature in the stationary frame must be (speed)2/a …
which is (2v)2/(v2/r),
= 4r :smile:
and
02 / 0
for the bottom
same reasoning … we know that the radius of curvature (at the bottom of the wheel) in the stationary frame must be (speed)2/a …
which is 0/(v2/r),
= 0 :smile:
ehild said:
… the acceleration at that point has also tangential component at which is the time derivative of the speed …
indeed, which is why i chickened out and specified dr/dt = 0 :wink:
Okay. So the radius of curvature for the top is 4r (which can be found out from doing geometry). A then is (2v)^2 / 4r = v^2 / r
The radius of curvature for the bottom is 0. And the condition for this is that
since the radius of curvature for the bottom is always 0 in this case.
I think that doing this
ehild
is easier.
However if there was acceleration in the translational motion, then i would just use
sqrt { at 2 + ar 2 } to find the magnitude of total acceleration
hi joej24! :smile:
is easier.
yes of course :wink: … that's why i wrote …
yes :smile:
a = v^2/r
the velocity at the highest point is 2vcom and hence acceleration is (2v)^2
1. What is the difference between linear acceleration and angular acceleration of a rolling tire?
Linear acceleration refers to the change in speed of an object in a straight line, while angular acceleration refers to the change in rotational speed of an object. A rolling tire experiences both types of acceleration simultaneously.
2. How is the acceleration of a tire rolling on a flat surface affected by the weight of the vehicle?
The weight of the vehicle has a direct impact on the acceleration of the tire. The heavier the vehicle, the more force is required to accelerate the tire and the slower it will accelerate.
3. What factors affect the acceleration of a tire rolling on a surface?
The acceleration of a tire rolling on a surface is affected by various factors including the weight of the vehicle, the coefficient of friction between the tire and the surface, and the radius of the tire.
4. How does the surface on which the tire is rolling affect its acceleration?
The surface on which the tire is rolling can have a significant impact on its acceleration. A smooth and flat surface will allow for easier and faster acceleration, while a rough or uneven surface may cause the tire to slow down or even come to a stop.
5. Is the acceleration of a tire rolling always constant?
No, the acceleration of a tire rolling can vary depending on the speed of the vehicle, the surface it is rolling on, and the weight of the vehicle. In some cases, the tire may experience changes in acceleration due to external forces such as wind or a change in the slope of the surface.
Suggested for: Acceleration of a tire rolling
