1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Acceleration of an elevator
  1. Nov 18, 2007 #1
    I need help getting started with this problem. Thanks.
    The acceleration of an elevator changes at a rate give by the function
    http://img232.imageshack.us/img232/2739/mathzy2.jpg [Broken]
    Plot the position of the elevator assuming that its velocity at t=0 is zero and the elevator starts moving from a zero ground level.
    2. Relevant equations
    3. The attempt at a solution
  3. Nov 18, 2007 #2
    Are you in a calculus-based physics course? The problem sounds like it calls on you to integrate this acceleration function to find the velocity function, then to integrate that to find a positive function, given that v(0) = 0 and x(0) = 0.
    This will be harder to deal with if you have to do it only graphically.
  4. Nov 18, 2007 #3
    I could use integration to solve this, then I have to use the values to plot a graph.
    Still need help staring this problem. Thanks.
  5. Nov 18, 2007 #4
    So wouldn't you be plotting the values of x(t) for different times? Also, is e in that function supposed to be 2.71828... ? So you have all the information you need to find the position function and calculate positions, no?
  6. Nov 22, 2007 #5
    e = 2.71828183
    I have integrated the acceleration equation twice to find out position. Then I plotted the equation on Maple and i got this graph, Can someone tell weather this is correct or incorrect way of addressing this problem. I also can't understand the Graph, according to the graph it says the the position of the elevator increases exponential after 5 second. Can someone explain the graph to me. Thanks
    http://img100.imageshack.us/img100/3210/mattttttsr1.png [Broken]
  7. Nov 22, 2007 #6
    - First of all it does not make sense to plot the position time graph for negative time values. You should graph the position function for t>=0
    - Secondly as for explaining the graph for positive t values note the following:
    The elevator at t = 0 starts at about 14 units away from the origin of your frame of reference and for t = 4 it will come towards the origin and then for t>4 it will move away from the origin.
  8. Nov 22, 2007 #7
    Thanks for the reply
    -The reason i plotted the graph for negative values is to get a perspective of what is happening.
    -Is the "y axis" refering to the floor number?
    -Also why is it moving away from the orgin at a expoential rate?
