Solving Acceleration Problem: Time & Distance Calculations
In summary, the problem involves a marble rolling off a table with a height of 0.8m and an acceleration due to gravity of 10 m/s^2. The questions ask for the time it takes for the marble to reach the floor and the horizontal distance it travels after rolling off the table with a speed of 2 m/s. The relevant equation is y = yo + vo*t - 1/2*gt^2 and the horizontal velocity remains constant.
gztiger
The surface of a table is 0:8 m above the floor. A marble rolls o the edge of the
table. The acceleration due to gravity at the surface of the Earth is g = 10 m=s2.
I am not sure about the equation, it was not given.
a. How much time does the marble take to go from the edge of the table
to the floor?
b. The speed the marble rolls is 2 m=s. How far does the marble travel
horizontally, after it rolls o the table?
Hi gztiger, welcome to PF1) y = yo + vo*t - 1/2*gt^2
2) Horizontal velocity does not change due to gravity.
To solve these problems, we can use the equation d = v0t + 1/2at^2, where d is the distance traveled, v0 is the initial velocity, a is the acceleration, and t is the time.
a. To find the time it takes for the marble to reach the floor, we can solve for t using the given values:
d = 0.8 m (since the marble starts at the edge of the table and falls to the floor)
v0 = 0 m/s (since the marble is initially at rest)
a = 10 m/s^2 (acceleration due to gravity)
Plugging these values into the equation, we get:
0.8 = 0 x t + 1/2 x 10 x t^2
0.8 = 5t^2
t^2 = 0.16
t = √0.16 = 0.4 seconds
Therefore, it takes the marble 0.4 seconds to reach the floor.
b. To find the horizontal distance traveled by the marble, we can use the equation d = vt, where d is the distance, v is the velocity, and t is the time. We are given that the speed of the marble is 2 m/s, so:
d = 2 m/s x 0.4 s = 0.8 m
Therefore, the marble travels 0.8 meters horizontally after rolling off the table.
What is acceleration and how is it calculated?
Acceleration is the rate of change of velocity over time. It is calculated by dividing the change in velocity by the change in time.
What is the equation for solving acceleration problems?
The equation for solving acceleration problems is a = (vf - vi) / t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
How do I solve for time in an acceleration problem?
To solve for time, you can rearrange the equation a = (vf - vi) / t to t = (vf - vi) / a. Plug in the values for acceleration, final velocity, and initial velocity to solve for time.
What units are used for acceleration, time, and distance?
Acceleration is measured in meters per second squared (m/s²), time is measured in seconds (s), and distance is measured in meters (m).
What are some common mistakes to avoid when solving acceleration problems?
Some common mistakes to avoid when solving acceleration problems include using incorrect units, not properly rearranging the equation, and not using the correct values for acceleration, time, or distance. It is important to double check your work and use the correct formula for the specific problem.
