Acceleration problem
  • Thread starter ryanbersa
a rocket is launched with constant acceleration for 16 secs and after 20 secs its reaches 5100m
what is acceleration during first 16 secs
what is velocity at 5100m
v=v0+at
I calculated the avg acceleration as 25.5 m/s^2
I calculated the avg velocity as 255 m/s^2
I know after 16 seconds the acceleration is -9.8 m/s^2
i have tabulated various quants to try make sense of it and even did a position vs time graph but i can get further
also did motion diagrams to show velocity vector and acceleration vectors
Answers and Replies
4,296
Suppose you call the acceleration during the first 16 seconds "a". What is the velocity of the rocket at time zero (as it is being launched)? In terms of "a", what is its altitude after the first 16 seconds, and what is its velocity after the first 16 seconds?
Chet
Doc Al
Mentor
44,946
1,216
How could you express (mathematically) the distance traveled during the first 16 seconds in terms of the unknown acceleration? (Call the acceleration "a".)
How could you express (mathematically) the distance traveled during the next 4 seconds?
What must they add up to?
Edit: Chestermiller beat me to it!
Velocity at start is zero and I don't have any values for at time 16s
Ok thanks guys I have an idea now so will give it another stab in the morning
Your help is much appreciated :) I managed the first 50 questions of this chapters exercise set but this one got me
Hi guys
If I use y1 = y0 + v0(t) + 1/2(a)(t)^2 then I get Y1=128a and Y2=8a
so if i understand Doc Al correct then this should add up to 5100 meters so
128a_1+8a_2=5100m
a_1=(5100-8a_2)/128
Nathanael
1,650
239
Why does Y2=8a?
What's the velocity at the beginning of Y2? What's the acceleration?
Edit:
Try using a velocity vs time graph. That's actually an excellent way to solve the problem.
(You'll need to know two basic "calculus" ideas: 1.) the slope of the velocity graph is the acceleration, and 2.) the area of the velocity graph is the distance. Since acceleration is constant, the slope is constant, meaning the graph is made of only straight lines.)
If you don't immediately see the solution, then imagining the velocity vs time graph is certainly a great way to jump straight to the final equation.
y1 = 128a
v= 16a
then
y2=y1+v1(t)-1/2g(t)^2
5100=128a+16a(4)-1/2(9.8)(4)^2
5178=192a
27m/s=a ?
and
Vf=Vi+a(t)
Vf=16a+9.8(4)
Vf=16(27)-9.8(4)
Vf=392.8
23
By trial and error on excel :
Plug in :
initial acceleration for 15 seconds @ 27.85 (m/s)/s
Then decelerate under gravity for 5 seconds
This should satisfy the results
dont have excel in the exam :)
Doc Al
Mentor
44,946
1,216
y1 = 128a
v= 16a
then
5178=192a
27m/s=a ?
Good! (Except the units should be m/s^2.)
and
Vf=Vi+a(t)
Vf=16a+9.8(4)
Vf=16(27)-9.8(4)
Vf=392.8
Good!
23
Phase 1 : accelerating under power for 15 seconds.
Phase 2 : decelerating unpowered for 5 seconds under gravity.
If you get the answer by mathematical means, you will know if your procedure is correct (because you have the answer) saving you further work.
You could post this enquiry on the mathematics section, you may get an improved response.
By the way the velocity at 5100 m is 368.8 m/s exactly, and an improved answer for the acceleration is
27.8533 (m/s)/s with the 3's recurring.
Ive based these calcs on inputting an arbitrary value for (phase 1) acceleration, then calculating the distance and velocity after 15 seconds (when the motor shuts down), this velocity is then used for the slowing by gravity stage (lasting 5 seconds) as the initial velocity.
Newtons equations of motion are used for both stages.
I altered the value for initial acceleration value until the distance was correct ( (trial and error)
The maths algorithm is beyond me, but it must exist or you wouldnt have been asked.
Hope this helps
Dean
Doc Al
Mentor
44,946
1,216
Those phases should be 16 and 4 seconds.
There's no need for trial and error. The math is straightforward, as ryanbersa has demonstrated.
23
oops, not reading the question properly, might as well use the algorithm again :
revised solutions (16 and 4 seconds)
acceleration = 26.9708333 (3's recurring)
final velocity (g at - 9.8 (m/s)/s) = 392.333 (3's recurring)
Related Threads on Acceleration problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
