Acceleration problems
I) A car slows down from 23 m/s to rest in a distance of 80 m. What was its acceleration, assumed constant?
II) A car slows down uniformly from a speed of 26.0 m/s to rest in 5.50 s. How far did it travel in that time?
what am i doing wrooong? am i using the right formula?
I) I used this formula: a=Vf-Vi/tf-ti but the problem doesn't give me time so it didn't work
II) I used the same formula ^^ 0-26.0/0-5.50=4.72 is not the answer
Answers and Replies
Well, you can find the time it took to travel 80m using Vavg and then find the acceleration. Or v^2 = vo^2 + 2ax
For the second part, you need to find distance not acceleration. Which is equal to Vavg*t
Ok, I got problem # II.
I still don't understand # I...
So I find the Vavg = (0+23)/2 = 11.5
am I right here?
Then I guess I plug that into the formula:
11.5^2=0^2+2 a (80?) >> I don't know what's my X
Help!!
kuruman
Insights Author
2,514
Since the time is not given, use the kinematic equation that relates acceleration, displacement and the squares of the final and initial velocity.
that's what I'm doing and I'm not getting the right answer
v^2 = vo^2 + 2ax
0=23^2+2a(80)
0=689a
Integral
Staff Emeritus
56
v^2 = vo^2 + 2ax
0=23^2+2a(80)
0=689a
How did you combine those factors? The first does not have an a in it so cannot simply be added.
kuruman
Insights Author
2,514
Your algebra is wrong.
0 = 232+2*a*80 is OK. It's the next step that is incorrect. Doing the number multiplications gives
0 = 529 + 160*a
You can't add 529 and 160*a to get 689*a !! To get 689*a you need to add 529*a + 160*a, which is not what you have here.
Instead, you say
160a = -529
a = -529/160 m/s2
ok,
0(final)=23^2(initial) + 2 a (80)
I got the 23 ^2 which is 529
then I multiplied 80 * 2 =160
then I added 529 +160 =689
oooooooh ok,
thanks a lot kuruman!! I really appreciate it.
Related Threads on Acceleration problems
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
