Homework Help: Acceleration vs Time Graph
  1. May 1, 2012 #1
    I'm practicing for my exam and so I'm studying off practice tests that my professor gave me.
    One of the problems is an acceleration vs time graph. The question is question #2 on the link below.
    http://facultyfiles.deanza.edu/gems/lunaeduardo/Physics50Exam1W11.pdf
    2. Relevant equations
    I'm trying to use
    Velocity = acceleration*time
    but I'm not given an acceleration
    3. The attempt at a solution
    I'm assuming because at t = 0s, velocity = 10 m/s.
    I understand that Acceleration is velocity (m/s) per 1 second but if velocity at 0s is 10m/s, how do you use that to calculate for a time at maybe, 1s or 2s?
    Any help will be great.
    Thanks
  3. May 1, 2012 #2
    BruceW
    hi there, welcome to physicsforums :)
    I've looked at the graph, and I think they made a mistake. The y axis of the graph should have values for the acceleration. As it is now, I don't think you can calculate anything from it!
  4. May 1, 2012 #3
    Thank you!
    Ya, I've been looking at the graph for a long time and trying to figure out why I can't get an answer. At first, I thought it was probably me just not understanding how a A vs. T graph works but after an hour of looking around and watching youtube videos and everything, I concluded that I don't think I can be that clueless...
    However, I feel like the "t=0s, then velocity = 10m/s" is where you are supposed to start at maybe?
    Its just hard to believe that my professor would give us an incorrect problem to study from for an exam :confused:
  5. May 1, 2012 #4
    ehild
    Maybe your professor meant that one scale on the vertical axis corresponded to 1 m/s2 acceleration. Try to solve it that way. And remember: acceleration is change of velocity over a time interval Δt: a=ΔV/Δt. In case of constant acceleration, V=V(0)+at, but the acceleration varies with time in the figure. In that case, the area under the a(t) diagram gives the change of velocity. For example, the acceleration-time graph encloses a triangle between 0 and 25 s. The height is 7 scales=7 m/s. The "area" of the triangle is [25(s) * 7 (m/s2)]/2= 87.5 m/s. It is the change of velocity between t=0 and t=25 s. To get the actual velocity, add 10 m/s.
    ehild
  6. May 1, 2012 #5
    BruceW
    possibly too much help there. But I do agree, the professor probably just forgot to mention what the scale on the vertical axis was meant to be, so you can still try the problem by taking a guess at what the scale is meant to be. (But if your professor has used a different scale, then your answer may not turn out the same as his, but it is good practice anyway).
  7. May 1, 2012 #6
    ehild
    Bruce, this is a very unusual problem for students unfamiliar with calculus and just studying motion with uniform acceleration. I do not think I gave too much help by explaining how to relate area under acceleration to change of velocity.
    ehild
