How do the accelerator pedal and rpm interact in an internal combustion engine?
In summary, the question asks how the action of the accelerator pedal affects the rpm of an internal combustion engine. The four quantities considered are compression ratio, air to fuel ratio, ignition rate, and air flow rate through the intake manifold. The compression ratio is relatively constant, while the other three are variable and contribute to regulating the engine speed. The accelerator pedal, linked to the butterfly valve, is the primary factor in controlling the air flow and therefore, the engine speed. The firing rate is dependent on the resultant rpm through either a distributor or ECU input.
  • #106
Locked Pending moderation
Likes 1 person
<h2>1. How does the accelerator pedal control the rpm in an internal combustion engine?</h2><p>The accelerator pedal is connected to a throttle valve, which controls the amount of air that enters the engine. More air means more fuel can be burned, which increases the rpm.</p><h2>2. What happens when the accelerator pedal is pressed down?</h2><p>When the accelerator pedal is pressed down, the throttle valve opens, allowing more air to enter the engine. This increases the rpm and causes the engine to produce more power.</p><h2>3. How does the engine know how much fuel to inject based on the accelerator pedal position?</h2><p>The engine control unit (ECU) uses sensors to measure the amount of air entering the engine and the position of the accelerator pedal. Based on this information, it calculates the amount of fuel that needs to be injected to maintain the desired rpm.</p><h2>4. Can the rpm be controlled without using the accelerator pedal?</h2><p>Yes, the rpm can also be controlled by the vehicle's cruise control system. The cruise control system uses the ECU to maintain a constant speed by adjusting the amount of fuel injected into the engine.</p><h2>5. How does the rpm affect the performance and efficiency of an internal combustion engine?</h2><p>The rpm directly affects the power and torque output of an engine. Higher rpm means more power, but it also means more fuel consumption. Engines are designed to operate efficiently at a specific rpm range, and varying the rpm can impact the overall performance and efficiency of the engine.</p>
  • Mechanical Engineering
14K
