Calculating Acceptance Value (Acc) from MC Datasets - Kim
In summary, according to the expert, the acceptance for two jet events is calculated by (njet=1 events + njet=2 events) / total events. If you want to calculate the ratio of two jet events to one jet event, my definition would be: \frac{\text{two jet events reconstructed in data}}{\text{one jet events reconstructed in data}}\times\frac{\text{acceptance for one jet}}{\text{acceptance for two jets}}where consistently and as before \text{acceptance for one jets}=\frac{\text{number of events with at least one jet reconstructed}}{\text{number of events with at least one jet generated}}in this manner, you do not need
penguindecay
Dear Experimental Particle Physicist,
I have a simple question on how to calculate the Acc value from a MC dataset. I wish to know the Acc value for njet = 1 in some MC dataset which has 1000 events say. If there are 1 event that has one jet, would the following Acc value be 1/1000 ?
Also if I was to introduce a second dataset, would the new Acc value be a sum of the two, or be similar to the above method, ie total output / total events ?
Thank you for reading
Kim
The acceptance is usually defined as [tex]\frac{\text{number of events reconstructed}}{\text{number of events generated}}[/tex]
From the onset, you see that there is a drastic dependence on the generation. Depending on whether you have the same definition as me, you would need to have at least one jet in all of your generated events for instance. If you do not have one jet at least in every event generated, I would classify your strategy as including part of the luminosity in your MC (it's not necessarily bad, just different definition).
If you were to introduce a second data set, you could treat the entire sample as just twice more statistics in a single MC sample. So the definition should remain the same, and provided you have small statistical fluctuations, the acceptance should not depend on how many events you generate.
Hope that helps.
Dear Humanino,
Thank you for your shift reply. That has helped a lot. Indeed the reconstructed has at least one jet. The two data sets are for the e channel and the muon channel, these having four data sets themselves. I am grateful for your help.
One last question has popped in my mind. I need to introduce njet = 2 into the Acc value. I have calculated the Acc for one dataset by (njet=1 events + njet=2 events) / total events . Would this be correct, or would I need to have twice the total events?
Thank you once again
If you want to calculate the acceptance for two jet events, my definition would be :
[tex]\text{acceptance for two jets}=\frac{\text{number of events with at least two jets reconstructed}}{\text{number of events with at least two jets generated}}[/tex]
Again, there are other possibilities depending on the conventions.
If your purpose is to calculate the ratio of two jet events to one jet events, I think what you need is
[tex]\frac{\text{two jet events reconstructed in data}}{\text{one jet events reconstructed in data}}\times\frac{\text{acceptance for one jet}}{\text{acceptance for two jets}}[/tex]
[tex]\text{acceptance for one jets}=\frac{\text{number of events with at least one jet reconstructed}}{\text{number of events with at least one jet generated}}[/tex]
in this manner, you do not need to evaluate luminosity.
Dear Humanino,
You've been a great help! That has sorted most of my problems out, thank you. Another thing has come up, and hopefully this will be the last question, I've realized that my data sets are of different partons. I done the calculation like so:
(Sum of weighted events reconstructed) / (sum of weighted events generated)
Would this be the correct approach?
Thanks again
Kim
If I understand correctly, you generate your partons with a flat distribution in phase space and take care of the cross-sections by weighting your events with the known parton distribution functions. So instead of having more partons at low x, you just give them a higher weight than at higher x accordingly, and same story for different flavors. In that case, your formula is correct.
Dear Humanino,
Thank you once again. I'm really grateful for your help. Thanks
Kim
Please do to take my advices for granted. I hope you cross check with a collaborator knowing better the details of your investigation.
Dear Humanino
Of course, I have a meeting with my advisor this monday. Thank you for your kind advise.
Kim
1. What is Acceptance Value (Acc) and why is it important in MC datasets?
Acceptance Value (Acc) is a statistical measure used to evaluate the accuracy and precision of a set of data. In MC (Monte Carlo) datasets, it is particularly important as it provides a quantitative measure of how well the simulated data compares to the expected or theoretical values.
2. How is Acceptance Value (Acc) calculated?
Acceptance Value (Acc) is calculated by taking the absolute difference between the mean of the dataset and the expected value, and dividing it by the acceptable range (typically set at 2 standard deviations). The resulting value is then multiplied by 100 to get a percentage. The lower the Acceptance Value, the better the fit of the data to the expected values.
3. What is an acceptable range for Acceptance Value (Acc)?
The acceptable range for Acceptance Value (Acc) varies depending on the specific dataset and its intended use. In general, a value below 10% is considered acceptable, while values below 5% are considered excellent. However, this can also depend on the level of precision required for the specific application.
4. Can Acceptance Value (Acc) be used for non-MC datasets?
Yes, Acceptance Value (Acc) can be used for any type of dataset where there is an expected or theoretical value to compare against. However, it is most commonly used in MC datasets as a way to evaluate the accuracy of simulations.
5. Are there any limitations to using Acceptance Value (Acc) as a measure of data accuracy?
Yes, there are some limitations to using Acceptance Value (Acc) as a measure of data accuracy. It is important to note that Acc only evaluates the accuracy and precision of the dataset as a whole, and does not provide information on individual data points. Additionally, Acc is based on the assumption that the errors in the dataset are normally distributed, which may not always be the case.
9K
  • Atomic and Condensed Matter
