Accumulation in space
  1. Feb 14, 2016 #1
    i was daydreaming in class today and i came through something that i was quite unable to prove on my own ...
    i am not sure if it's fully related to math or physics but here it is , it's no big deal .
    imagine you have a point in 3 dimensional space . and a number N of objects of Random volumes and shapes placed at random positions in the 3 dimensional space .
    now imagine that there is a force that will pull all the objects to that single point as if it accumulating them on top of they each other all around that point . as if the point has infinite gravity . after all the objects are accumulated on the point and everything reaches a stable state where no object is moving . a new object S is formed , where S is the object made by the accumulation of all the objects around the point .
    i want to prove that if N -> oo then S is a perfect sphere .
  3. Feb 14, 2016 #2
    the thing that i am interested about regarding this , is the fact that the initial position of the objects in space should not at all matter .
    that is supposed to be a Propriety of "Random" and infinity being together . though i cannot figure if this is correct .or if it can be proven .
  4. Feb 16, 2016 #3
    well ... if you all the objects have equal volumes then the problem would become simple . also if the volumes of the objects would be limited by a Real number L it would also be simple to demonstrate . but with the volumes being fully random it turns hard .
  5. Feb 16, 2016 #4
    A perfect sphere is an imaginary mathematical construct; your question is about the real, physical world. The answer is that you don't need an infinite number of objects, you simply need enough mass so that gravity is strong enough to overcome the forces holding the objects together; apart from some surface irregularities they will then form a sphere.
    This is a useful concept and is now part of the definition of a planet.
  6. Feb 16, 2016 #5
    What do you mean with "random volume"? Do you mean that every two numbers have equal probability of being the volume of the object? In this case, a random volume doesn't exist. So your problem is ill-posed.
  7. Feb 16, 2016 #6
    interesting . i spent a long time in the past attempting to understand what a perfect sphere is . what i did get to essentially , is that a curve or any curved shape cannot exist in a limited 3 dimensional space with a unit that has a specific shape , (unlike a cube , it can exist if the unit is a cube) . for a sphere to exist in 3 dimensional space , the unit has to be infinitely small , though then distance would make no sense and you cannot construct anything out of it . though imagine an object of any shape having a real size or volume , for example a volume of 1 m*m*m in space . regardless of the shape of the object . if you have an infinite number of it and you attempt to construct a sphere out of that whole number . the object is infinitely small when compared to the sphere so then here , the singularity is not the fact that the unit is infinitely small but the fact the number of unitary objects is infinite , so i have the right to call the formed sphere a perfect one .
    that's what drove me to start thinking about random shapes and volumes in the first place . what can be disregarded when dealing with infinity and shaping singular objects .
    (of course i also suppose that the 3 dimensional space is infinite)
    i am having a hard time attempting to translate this from my main language to english .
  8. Feb 16, 2016 #7
    the main reason behind this is the fact that i wanted to see if i would be able to disregard the variations of volume .i do not understand what you mean with
    "every two numbers have equal probability of being the volume of the object"
  9. Feb 16, 2016 #8
    A (perfect) sphere is a 3 dimensional surface containing every point that has distance r (the radius) from a single point (the centre). Note that in maths, a sphere is not a solid object, we call the solid bounded within a sphere a ball.
    In the real, physical world it is fine to call a solid object which has this shape a sphere. But in the real world objects are composed of particles of finite size (which are constantly moving in an unpredictable way) and so it is never possible for them to exactly form a cube, sphere or any other perfect shape.
  10. Feb 16, 2016 #9
    i know , with "sphere" i mean the solid object bounded by the external surface of the sphere or the sphere itself .
    here i suppose that i have a unit for 3 dimensional space that i construct things with .
    it's not the physical world we are speaking about here .
  11. Feb 16, 2016 #10
    Remember this is the "General Math" forum and we deal with things mathematically here. Micromass was stating that your problem is not well posed mathematically; explaining why would probably be a diversion from the main topic of your thread.
  12. Feb 16, 2016 #11
    i was lost at first , couldn't figure where to post this. i didn't post this in "physics" section because the 3 dimensional space that i am mentioning here is not the real one .
  13. Feb 16, 2016 #12
    Oh in that case there is no problem. We consider the limiting case as the size of the objects tends towards 0 - this overcomes problems associated with infinite numbers of objects.
    Unless constrained, objects will move from a position of higher (gravitational) potential to lower. It can be shown that total gravitational potential is minimised when the objects form a sphere. As the size of the objects tends towards 0 the sphere becomes perfect.
  14. Feb 16, 2016 #13
    gread ! as the size of the objects tends to 0 the object tends to become a perfect sphere . now what about if the number of objects tends to infinity ?
  15. Feb 16, 2016 #14
    As the number of objects tends to infinity their size must tend towards zero, otherwise the solid becomes infinite and its shape is not defined.
  16. Feb 16, 2016 #15
    we need to apply more singularities to this . now l'ets go back to the same 3 dimensional sphere . if you get the 3 dimensional sphere and infinitely enlarge it , it will be an object of infinite size and that's right but it will still be a sphere , it just happens to be infinitely big .
    in fact , since the sphere is formed with an infinite number of infinitely small objects it must be acceptable that for an object to go from being infinitely small to having a real volume like 1 m*m*m it has to be infinitely enlarged , so a singularity has to be applied to break the first one .
    there is a certain singular enlargement that would turn the infinitely small unit to a unit that has a real size , the same enlargement would turn the perfect sphere to a sphere (that i like to call perfect) but that also happens to be infinite in size .
    so essentially we reversed the singularity , first the sphere had a real size and the objects forming it were infinitely small , but then the sphere became the one that's infinitely big (the singular element) and the constructing object became the real element due to it's new real volume .
    both of them should be called perfect spheres.
  17. Feb 16, 2016 #16
    In maths we use the term "singularity" when something is not defined. I don't understand what you mean by "apply a singularity".
    That is not correct. How would you define the centre of such a sphere?
    None of this makes any sense mathematically. In order to develop a better understanding of how it is possible to deal consistently with infinite and infinitesimal quantities you should study calculus.
  18. Feb 17, 2016 #17
    thank you . i am not taking "Topology" but i really like it .
    do you think it's possible for me to study it on the internet ? thank you
  19. Feb 17, 2016 #18
    I am not sure that there is a good toplogy course on the internet, although what you are probably looking for is differential geometry rather than topology.
    But before you get there you need a sound understanding of analysis. Again I don't know of a great foundation for this on the internet, but I suppose https://www.khanacademy.org/math/precalculus/limit-topic-precalc [Broken] goes most of the way.
  20. Feb 18, 2016 #19
    i was listening to a mathematician , he called himself a "Model theorist" i don't know what that means , and he said it's ok to define a number k . that is superior than any other number in N or R , but that is not superior than k itself or k+1 ... etc .
    the thing is , people these days allow a sphere to be placed in a 3d space , even though the smallest unit to construct that sphere is infinitely small . relative to the smallest unit in the sphere the Radius of the sphere would be infinite .
    so that if i let the radius of the sphere be k . then the smallest unit that constructs the sphere would be a finite number that is not infinitely small .
    one can ask how will the center of that sphere be defined . well you allow a sphere of radius R to exist while R is relatively infinite relative to the used unit same as K .
    and both the spheres en-capsule an infinite amount of points whether the radius is real or not , since if the radius is real the unit is a singularity and if the radius is K then the unit is finite .
    with unit i mean the smallest thing the space allows to exist .
  21. Feb 19, 2016 #20
    jbriggs444
    You really really need to learn some real analysis. None of this is sensible. Most is just word salad.
    In the real numbers there is no "smallest thing". For every x > 0 there is a y > 0 such that y < x. The infinite and the infinitesimal do not work the way you think they do.
Similar Discussions: Accumulation in space
  1. 4D space? (Replies: 21)
Loading...
